When ever i try to connect to my WIFI there is a lack of wifi singnal even though I am right above my network router. This problem occured one week ago on the 29th of dcember 2014. Before i would get full bars on the wifi connection but now I don't know why is has suddenly dropped.
Hi @kmano1,
Do you have the same issue on any other WiFi router/network?
And to be sure, have you restarted your router and tried to change the WiFi channel?
Yes i have the same problem with other routers. It make it very difficult to surf the internet when it keep getting a poor connection.
@kmano1, so this would indicate that a third party application is causing the problem. There's a couple of options here.
First, I suggest is to update everything. Go to Settings > About Phone > Software Update and make sure you have the latest firmware. Next, update all your downloaded apps in the play store.
If this doesn't work you can either start going through your installed apps and uninstall them one by one, testing after each one to identify the culprit as uliwooly said, or alternatively run a software repair which will completely reset your handset. If you do the software repair just try to test after each app you reinstall to identify which one causes the problem.
