My Xperia Z was working fine then all of a sudden it shuts down. It won't turn on when I press the power button or when I press the volume up/down etc buttons + power button. When I connect it to charger, it blinks twice red light repeatedly for some time then stops... Any solution?
did you give it a water test recently - if check under the covers for pink indication
if not it sounds like some hardware has failed, you could try an update repair with SUS but I doubt that will work
next step to return it to a service center or to the retailer
Repair details can be obtained by contacting your local support team directly. You can find contact details here: http://bit.ly/wPKtf6
What do you think about this forum? Let us know by doing this short survey
