Hello.
My Xperia is about a year old, and I have recently gotten a hold of a new PC. This issue started when I tried to connect my Xperia V to my new PC through USB connection (Keeping in mind, I have done this a countless amount of times on other PCs) and now, my Xperia V instantly died the moment the connection was made. Whenever I try to charge the phone through a regular charger, the phone vibrates continously with the power indicator in a flat menacing RED light that won't die out. The vibrating won't stop unless I unplug my phone from charging.
I need help please!
I tried doing the Hold Power + Volume Up/Down and it has done nothing at all.
Have you tried to remove the battery for a while? Then try to charge for a couple of hours and try to start it again.
If the the phone still doesn't charge I suggest that you try to repair the phone software using PC Companion:
In PC Companion, press start on Support Zone > Start on Update the phone/tablet software > click on the blue highlight (Repair my phone/tablet). Do this without the phone connected. Follow the instructions on screen to perform the repair.
Sorry to hear that. In that case I suggest that you have your phone examined by a service center. Please contact your local Xperia support team for more information:
