i just got a new xperia u and is overheating, its been less than a week since i got it.... any help with this??,
Not really! The Xperia U does overheat when its used a bit hard! if many apps and games are running it does overheat! in that case close the apps for a while, it will be ok. if you play games or run an app for like a bit of a long time it is usual that it heats up! 😃
The term "overheating" is a bit tricky to verify wether it's working as it should or not. What you though can say concerning it is if the phone get's un-comfy holding it's not acting as it should. Then it would be wise to hand your phone in for a check and eventual fix.
Contact your retailer in that case and they can help you further on.
