Xperia U GPS Precision
I have buyed a sony xperia u but the GPS fix is too long and when it fixed my position the precision is too bad like altitude negative! I tried to change the phone and restore but the problem remain, any suggestion?
It's sound like software problem, it's possible?
I used GpsFix and GPS Status apps from google play.
       thanks
42 REPLIES 42
k_saurabh
Even i am facing similar issue. When i was using the default OS .156 then it was working fine but after upgrading it to .184 this problem started up. When i try to use maps and try to locate my co-ordinates then it asks me to enable the location services i.e. GPS and when i switch it on it says 'your location is temporarily not available'. I too suspect that it is unable to connect to the satellites properly coz i got this error even when i was in an open space with no signal drop. This seems to be a S/W bug and as mentioned above should probably be resolved in ICS update. Eagerly waiting for ICS !! :smileygrin:
vigi
Hey,
I have the same GPS problem with Xperia go. Solution could be to use “GPS Test” app. In the settings it has ‘Clear AGPS’/ ‘Update AGPS’ buttons. Today my mobile was unable to connect to GPS for more than 10min. After Clear/Update AGPS it took less than 3 min to get decent connection.
ADIE63
Hi all,
Had the same problem as most people GPS fix taking upto an hour, on XPERIA U,
Well  went to the PLAY STORE  had a look round tried different Apps and one that seems to work great for me is called    TRACKERBOOSTER  when i run this i get a fix within a couple of minutes
give it a ago guys its free.
Slightly_smiling_Face
Message was edited by: ADIE63
cyberdad
Trackerbooster doesn't solve the problem
cyberdad
Tried that also without succes
Arnab
Enthusiast
just wait till ICS, it will be solved in ICS.
Bardia
hey Oscar,updating to ICS didn't Solve GPS Problems ...
cyberdad
promises promises
Rado77
Using tool GPS TEST i see that i catch 7-8 sattelites with less than 1 minute  Winking_Face  With French ICS I had the same problem as you - 3 minutes, 7-8 sattelites found but GPS still wasn't connected
Arnab
Enthusiast
if rooted u can use FastGPS app.
