xperia privilege app problem
Marty87
Good morning
I've a Little problem. I've done the latest upgrade for the xperia privilege application. But when i open It i have An error:
At Line 361column 2 not Well formed (invalid token)
Then the app is Closed....why?
Please help me
Thanks
13 REPLIES 13
Johan
Do you get this independent of Internet connection? Do you get this error using Wi-Fi instead of mobile networks or vice versa?
Marty87
Hello!!
I've the problem in both of the two cases...Now i have See that other People in the Google.play had the same problem...maybe is a Sony problem?
Johan
It could be some kind of local issue. Beacause I'm not able to replicate this.
So I suggest that you raise this with your local support team to check how to proceed with this in the best possible way.
Local support.
Webs424
I am having the same problem.
I installed the 4.3 update last night and now when attempting to accept the EULA on the Xperia Privilege app.
A message box pops with the following:
"At line 3163, column 2: not well formed (invalid token)"
Pressing OK closes the app.
I have already contacted Support via Xperia Care they directed me to Developer Worls Mobile which further pointed me to this forum.
I have tried clearing the application data and cache and even re-installed the application.  This happens every time I try to open the app whether I'm connected via my home network or using my mobile internet.
There is obviously some issue with the code for the current version of the application running under 4.3 and would like for it to be patched as soon as possible as I still have content that I would like to download.
Thanks in advance for giving this the attention that it deserves.
MastroPSX
I have the same problem, could someone help us? I have varius download. Could someone upload previous version?
Sam
Legend
Legend
@Webs424 - I have been able to replicate this so I escalated it for you. I will update here once I have had a response.
What are your thoughts about this forum? Let us know by doing this short survey.
Webs424
Thanks!
clydebank
Did we get any updates or resolution to this problem?
I am unable to access the privelege app, same issue.
Sam
Legend
Legend
Hi clydebank and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Xperia Privilege has been merged into the Xperia lounge application so all available promotions will be found there.
