xperia p notification problem
Gaurav8180
day b4 yesterday i updated my xperia p to ICS. till now all went good but just 10 min b4 notification ringtone doesn't seem to work, the phone only vibrates while notifying something(new message, or any popup....etc ). please help me out in this. tried changing my notification tone, set the volume to max but nthng worked for me.
100 REPLIES 100
Nalee
Hi ottobre
If you don't mind can you share some ringtone apps that you are using. Because some apps use lot of battery power and some time some apps couse to have a lag when using the phone.
Any way thanks for the contribution.
islam
hi every one i found solution for this proplem change your network operator such i was used etisalat now i am using vodafone and the proplem solved try other networks in our countries and write to me         islam from egypt
islam
Nalee
Hi islam
OK.... I need some clarifications about your solution.
1) In your country etisalat network operator; did they use USSD service? (If you don't know about this service plz visit http://en.wikipedia.org/wiki/Unstructured_Supplementary_Service_Data)
2) If I change to some other network operator and re-change to my previous operator then what happen? Will the problem solve or re-excites?
therualex
frnds..i have found a workaround for this problem..the issue is because of the USSD code running after we make a call. So what we can do is set default notification tone to silent and keep separate notification tone for your text messages, email, fb notifications, gtalk etc by individually going into the setting of the respective apps. It will work fine after that. The defect is not a Sony one. It is present in all android ICS devices and hence it is google to be blamed.
Nalee
Hi therualex,
Thanks for the solution. But how do i keep separate notification tone for text messages, email fb etc. Becouse some apps like yahoo mail app doesnot have a setting to set the notification tones.
Do I need to install separate app to set separate notification tones for thoese text messages, email fb etc.If so can you recomend a good app for set notificaiton sound separately for each app that I have installed.
therualex
Hi Nalee, well I don't use yahoo mail app so cannot comment on that. but most apps like whatsapp, gmail, gtalk(now hangout) have their own separate notification setting. just check carefully in the settings of the app, it might be there.
Nalee
Hi therualex
Thanks for your help. However I just got the JB update for my phone. The built number is 6.2.A.0.400.
I'm very happy to say that all the bugs that are in the ICS have been fix in this JB update and hope you guys also update your XP to JB built number 6.2.A.0.400
Most of the people in this community have stated that there is a lag in the call log app. Yes I agree with that. There is a small lag compare to ICS. But it can be acceptable becuse JB is more heavy than ICS.
Thanks SONY.
jackxperiaP
installed the latest .100 update too but still facing the notification problem in my device ..:smileycry: but once if the set the default notification to silent then i don face any problem so it clearly shows tat the other programs like watsapp, wechat or anything doesnt harm it Angry_Face the only enemy is the ussd code running and y cant sony fix this:smileyangry: but i heard also tat some guys don face notificaiton problem even thou the default notification is set Thinking_Face .. how to rectify or who ll give a proper explanation to this as y only a few faces the problem while the other with the same settings don face it:smileycool:
Nalee
How about the notification sound bug. I think it is still there.
