xperia p notification problem
Gaurav8180
day b4 yesterday i updated my xperia p to ICS. till now all went good but just 10 min b4 notification ringtone doesn't seem to work, the phone only vibrates while notifying something(new message, or any popup....etc ). please help me out in this. tried changing my notification tone, set the volume to max but nthng worked for me.
100 REPLIES 100
savio_1988
Hi Gaurav,
I am facing the same as u r my friend....its very annoying....please reply to my post as soon as get an update to solve this notification problem.....would be of great help..
Thanks
sudhu122
Guys I just found that Sony is releasing new Firmware for Xperia P ..lets hope for the best..the only problem is that we dont know when its gonna release in our place if it ever does and also dont know if the notificatiobn sound problem will go away.
Check this link
http://www.xperiablog.net/2012/09/20/new-ics-firmware-6-1-b-0-559-certified-for-xperia-p/
topazonic
Hello guys, make sure you don't have any app installed such as friendcaster which has option of notification quiet times. It will stop your notifications from ringing system wide. If you have then disable the notification quiet time setting or set it as per your prefrence so you don't miss other notifications. I earlier had the same issue and the culprit was friendcaster in my case as I had set notification quiet tiems. Winking_Face Just dsiable that setting in the respective app. Hope this helps...
ganeshkhose
Hello Guys,
My phone is just 4 days old and after upgrading to ICS I am facing the same notification issue..........., till now i have not installed any apps like friendcaster......., please update me once any one got the solution or any information on this issue.
Hello Sony Support Team,
It would be greatfull, if you guyes give some updates on this issue.
Thanks in advance Slightly_smiling_Face
Petter
Enthusiast
If it still doesn't work after the update it's wise to try performing a repair also first of all. You can perform it with PCC in the section called Support Zone.
You can get PC Companion from the link below. Slightly_smiling_Face
kiro_gr
I think the support team should stop telling people to perform a repair on their device because it ain't getting people anywhere to sloving the notification issue, instead of this, try to find real solutions to the issues users find.
thnx
Gaurav8180
Yes you are rite my friend. Sony should consider this problem ASAP and fix it in the next ICS release. This problem has become evident among many Xperia P users now. So this is the right time for sony to go for a hit. just do it Sony:smileyhappy:.
MaxSteel
hey m having the same problem on my Xperia P...
but i have also noticed while chatting on Gtalk i get notification tone...but other wise for anyother event like (sms, email, whatsapp) i don't get anything... Slightly_frowning_Face
I have tried everything what the Sony Customer Care has told me to..
1. I have tried to Update again.
2. used SUS.
3. factory reset.
4. repair.
but still no luck..when i restart my phone notification works but only for a few hours..which means obviously there is nothing wrong wid the setup or settings...
SonyXperiasupportteam PPL
I M A HUGE SONY FAN..nd i like Xperia P a lot...Its a gud phone really snappy to use...great display...gud features...have no other issues..
but if so many people are having the same issues...I guess you should realy accept that something is wrong..which won't just get fixed by the 4 points that u guys tell us to do.....
I REALLY LOVE MY XPERIA P..nd Notification being the only problem...I think its a realy great buy...
but PLEASE FIX THIS ISSUE...
Menace1
Hi guys, I assume many of us must have Watsapp installed, just like I do. I had been facing the same problem ever since I installed the ICS build. But to my surpirse, the latest update to Watsapp has somehow been co-incident with my notification tones working normally all throughout the day. Do you guys agree?
kiro_gr
nah, I thought whatsapp is the issue, so I removed it totally, and I'm still facing the same issue :S
