I´m just wondering why Sony decided to go with a 1305 mAh battery in the Xperia P. Can someone tell me the reason for that? Are there any technical or space limitations in this phone i´m not aware of?
Even the HTC Desire has a 1400 mAh battery altough it was announced exactly two years before Xperia P. I would have loved to buy this phone but as the battery is quiet low compared to other phones, which still last not nearly as long as i´d call it ok, i seriously doubt that i´m going to buy it unless someone told me a really good reason why they decided to stick with a battery which is low like that.
I rather get a 3300mAh like the motorola Droid Razr maxx
Holy ****! I didn´t know that this is already available. And now can someone tell me again why this phone has 1300 mAh against 3300 mAh in a phone that´s not soo much bigger in size, is 50 - 100 € more expensive and will probably be realeased in the same quarter?
Exactly, and its quite thin
http://www.gsmarena.com/motorola_razr_maxx-4666.php
Razr maxx (4.3in display)
| Dimensions | 130.7 x 68.9 x 9 mm |
| Weight | 145 g |
Xperia S (4.3in display)
| Dimensions | 128 x 64 x 10.6 mm |
| Weight | 144 g |
Xperia P (4.0in display)
| Dimensions | 122 x 59.5 x 10.5 mm |
| Weight | 120 g |
手机做的小,电量又要多,成本又得控制,目前的民用科技支持下是矛盾的.
this is an Enlgish only forum
translate.google.com
coldtotti wrote:
Small mobile phones do, but also more power, cost and get control, it is contradictory tothe current civilian technology support.
Can someone tell me what this is supposed to mean in proper english?
I think coldtotti was trying to say that small batteries go against real life usage and needs
Ah ok thanks!
If that is what he wants to say i totaly agree with him!
Is ics upgrade can boost battery life,, im using xperia p?
Hi, i jz wonder since xperia P is built-in battery, in case sometime the phone will jam & bcome black screen...then you cannot do anything until u need to remove ur battery off/on then it jz can restart the phone again...if facing the same problem to xperia P, how i going to do in order to restart it..??
