Hey there!
Not sure, if this is a lens or software issue, but images which I take with M2 are just awful. Blurred, lack of detail. I also have Xperia Arc, which is a 2+ year old phone, and if I compare images, pictures taken with M2 (8mpix) are just far worse. Any sollution to that, or is it only me lucky again with some faulty Sony phone. In short, should I return my phone back or is there any software sollution incoming?
Greetings!
Just an update on mine, I bought some nail polish remover - with acetone and gave it a thorough scrub. I think it has made a small difference but not substantial. Certainly the magenta coloured coating is still mostly there albeit quite fragmented. I can also see some dust has become lodged between the outer glass and the lens itself. Thats definitely not going to help matters. I presume opening the phone to remove that is going to be a tricky procedure? Yes I know I could take it to an authorised dealer or have it sent off for repair etc under warranty, but for me (and presumably for many others) I cannot be without my phone as I rely on it too heavily.
I'm currently using my old phone (a Nokia N8) as my camera and uploading the images tethered by wifi off the M2 for any special occasions that I need decent pictures. Inconvenient yes but until I can afford to replace this phone (18month contract), I'll have to make do.
If anybody has any advice about opening the device to clean or upgrade the lens via some sorta hack, that would be useful. I'm not hugely concerned with voiding my warranty.
I did think of using Toothpaste but thought it might be too abrasive and damage the glass under that blue coating. If you've had good results with it though, I'm definitely going to try it too!
I tried toothpaste today, must say it seems to have helped quite a lot.
I just used some sheets of tissue and some cheap plain white toothpaste and scrubbed for a couple of minutes.
I could see the blue on the tissue I'd used from the coating coming away from the lens.
In scrubbing I seem to also have moved a peice of dust that was behind the lens so that problem seems to be resolved now too.
Much better!
i am also disappaointed with the way the SONY is handling the customer ,The camera is very Poor .Pls dont buy it.Front is very poor and main camera is also not very good in low light condition.
I have m2 aqua, and I am preety satisfied with the quality of the back camera. the front one...well... i can't expect more...i knew it has only0.x when i bought my phone. as far as I know aqua doesent have a better cam that just m2. herețs a sample
hello! I am just wondering if rubbing toothpaste on the camera lens and removing the the blue covering void the warranty of the phone...
The Sony Experia M2 is the worst camera phone I have owned, it is never sharp, it hunts for focus all the time, my Experia Ray which is 3yrs old is by far superior. If it's a good camera phone you are looking for then the M@ is not for you.
Following a post elsewhere I cleaned the lense with a polishing compound (T-cut) and it has made a great difference to picture quality. it's as though the lense coating had become clouded over time, and coldn't be removed by normal cleaning.
Pete
