Ok so i have an xperia Z (C6606) that has been hit by the infamous sleep of death bug. While i was useing it my screen went black and unresponsive. I am unable to connect my phone to SUS, and have tried many proposed solutions from this board and a few othes. At first i had no LED when charging, but after letting it sit for a day i get 2-5 minutes of red LED then no LED again. Hard reset(volume up+ power) does nothing on or off the charger. Does anyone have any advice?
Hi Not_so_happy,
Welcome to the community,
You could try holding down the Power Key and Volume + button for 30 seconds and then plug in the charger for at least 2 hours and then try powering the device or trying the software repair on the device.
Have you tried to perform a software repair via PC Companion?
http://support.sonymobile.com/global-en/tools/pc-companion/
In PC Companion you press start on Support Zone > Start on Update the phone/tablet software > Repair phone/tablet (the blue clickable link in the message) > Follow these steps without having your device connected to the PC.
If this does not help or work, I can only suggest that you contact your local support team for further information how to proceed with this in the best possible way:
