Wifi problem after ICS update
mario386
I have this problem, that when I connect to the internet with my Xperia P throu wifi it will connect but after a minute it will not load pages anymore.
Everything works fine when connecting to the internet with DATA TRAFFIC.....what should i do?
Please help - everything was fine before with Gingerbread.
I updated to ICS yesterday on the 24th/aug.12.
Would it help if i repair the firmware? - and when repairing will all my previously installed Apps be deleted?
I'm from Estonia!
Best regards,
Thank you....
Mario
205 REPLIES 205
iproute
My German is a bit rusty but from what I can understand in this forum they are discussing wifi issues after ICS upgrade with certain routers.
Also in another thread on the same site - http://www.android-hilfe.de/sony-xperia-p-forum/264368-neue-firmware-82.html one of the guys announces that he was able to upgrade to 6.1.B.0.550 but that the upgrade was Vodafone specific...hopefully it will get released soon and will have a fix for our wifi issue....
iproute
Mickyb99,
What is your baseband version if you don't mind me asking?
Mine is:
u8500-49020804-P2H_EC01
iproute
Actually nevermind...found out it doesn't affect the wifi radio...
iproute
In desperation I tried a different firmware - generic world (and previously also had tried the central european one). In case you are also tempted - don't. Save yourself the hassle and frustration of reinstalling all the apps. Same behavior with that firmware too.
Alok1
Hi All,
I have recently upraded to ICS, and after that I have a unique problem with the mobile's wifi.
After mobile is connected to wifi for about 2-3 minutes, it does not disconnect.
I tried switching off the wifi, even enabled the flight mode (so that the wifi is deactivated), but the device simply don't disconnect from wifi.
I even tried to remove the wifi settings by "Forget" Network, but no luck.
To stop wifi, I have to switch off my device
Is there any patch or settings I should try, or is factory reset my only option.
mickyb99
Hey Iproute,
For the record my base band version is the exact same as yours. Also, I did a capture of the non-working router this evening. I guess it's the same behaviour as yours whereby I get a couple of power management packets being sent from the phone and not much else happening.
iproute
Thanks for checking!
I also noticed that the phone is happy to return icmp replies all day long but any other kind of traffic "through" the interface makes it go into a deep coma.
People on other forums (from what I was able to translate) in Germany, Spain and I believe even Russia are having the same issue...
I think if the Sony excutives were required to use this phone the issue would have been fixed by now Slightly_smiling_Face ...
cal168
Hi all,
My Xperia P have the same problem.
and such as I connected wifi-a in company in morning, then connected wifi-b in home in afternoon it will not work via wifi-b
And I can't turn off the wifi; only when I reboot it.
Baseband version :
u8500-49020804-P2h_EC01
Kernel version :
3.0.8+
BuildUser@BuildHost #1
SMP PREEMPT Fri Jul 13 14:59:29
2012
Build number :
6.1.B.0.544
damirdruzic
I have th same problem. When I connect to the internet with my Xperia P throu wifi it will connect but after a minute it will not load pages anymore.
I updated to ICS yesterday on the 9th/SEP.12.
I have Xperia P
Kernel version :
3.0.8+
2012
Build number :
6.1.B.0.544
I'm from Estonia!
Sony please help and repair that stupid bug!
//Damir
dimon2242
I have after the update is connected to WI-FI 10 minutes!
Originally wrote "Auntifikatsiya" and then again "Connection"!
