Hi, my phone having problems connecting to wifi directly after updating to ver 4.3. At first the wifi connection disconnects at random times however, it competely can't connect to my wifi today. When i checked the settings it showed association disconnected and it won't even show up for availability of connection even when i'm in the wifi range. I really need a fix fast as i need my phone for work. Thanks for any help in advance.
Model Number: C5303
Andriod Version: 4.3
Build Number: 12.1.A.1.201
Kinda **bleep** that there is no official help to this problem when so many people are facing this problem.
even I am facing this problem
Afater all how many times are we expected to reapiar using SUS or PCC. H ow much data is required to reinstall the entire applications? isn't there any other solutions!!!!!!
I always see in this forum the common solution to any problem is "reinstall or repar using PCC"
SP does seem to have problems with routers that are not Wi-Fi certified. Not certified routers may work with laptops but SP cuts the connection frequently.
When I had to buy a new router for another reason, I made sure it was Wi-Fi certified, and the connection doesn't drop any more. My normal range is abt 10 m with a couple of walls and a ceiling between.
The SP firmware build is .205.
Ridiculous. There ain't no fixes for this "Rejected Association" issue from Sony. I even found more people with the issue in "newer" sony phones/ tablets (like Xperia ZR & Tablet Z). It's incredible how the Support Forum doesn't supply any support at all, everytime WE came with an issue.
