hi im having the same problem and now around 3 weeks after battery problem same as yours my signal is jumping from 4 bars to 0 even when just sat in same place where i always have 3 bars,maybe the two probs im ahving are connected and a third is on the way which would mean phone is on its way out after only 4 month
your problem maybe due to the fluctuaions in the signal range.Its rather erratic, if you are using a 3G.I have this particular problem only when it comes to around 35%.Otherwise the battery is stable.someone has to give me a solution.
I have recently purchased Sony Xperia L, the phone is excellent and has no issues until recently i found a bug in the phne's battery. Whenever my battery reaches around 50% it suddenly drops t0 43% or 45% in a minute when the phone is idle. I dont use any battery doctor type of apps but i do use Clean master. Suggest me a solution ASAP. Thanks!
I think that phone app has highest battery usage with data dormancy failure... We need software upgrade to repair this bug
