water get inside the phone. Can't start, no vibration. but when i plug it to the charger the led blink once coloured red, after that the led disappeared. unplug the charger and plugged it in, the led still blinked once, then disappeared again. can fix it or not?
*using the wall charger
*water get in from the ear speaker.
sure any time no problem
still not working.. *crying*
Connect the phone to wall charger.Try this:force restart the phone(power button+vol up until the phone vibrates).
still not working. but led blinking once red colored.
Keep it charging for 2 hours,repair phone software with sony update service.
how can i repair it? the phone can't boot up, even in flash mode also can't. fastboot mode also. the led blikning when i connect the phone to the wall charger and pc. after a 1 second the led disappearead. unplug and plug in back, the led come back.
But if you keep it connected to a charger,even though the led does not turn on,might it charge? If the repair option does not work,the only thing you can do is take the phone to a sony service...
if the phone come a life, can it be repaired by pc companion or sus? because the phone is unlocked and the phone was running cyanogenmod11 by munjeni build 6.
So your phone is rooted.Rooting is not my strongest knowledge...but I guess you could install official software with SUS.
i think it will not work, need to use official sony flashtool or unofficial flashtool to flash the stock rom. hmm. i will try it tommorow, because currently now is 12.28 A.M in malaysia. need to sleep. hope the method u give will work tommorow, if not, need to tell my dad the truth.
