VPN problem in Xperia e
hsanavi
Greetings to you I have an Sony Xperia E1 dual When I want to install vpn on it the following error is displayed. Please advise please. Thank you. "Unfortunately Settings has stopped "
6 REPLIES 6
Bandolero
Your trying to do the setup manually or installing an application.
If your doing a manual setup which settings your up to? PPTP or L2TP?
Nico83
Exactly the same here. The Android VPN implementation doesn't work in general anymore since the Xperia E1 update to Android 4.4.2. So VPN is not usable at the moment.
An error that has to be fixed by Sony. Which they will hopefully fix asap.
rishi-
same here as well
ArisArts
Same Here Slightly_frowning_Face
Pedrohenry2734
My VPN isn't working too
adrinsc
My vpn dosnt work too.and lock screen ability
