My memory card seems like got some virus. All the folder are showing like the shortcut in windows.
Please help what I need to do.... I have lots of data in memory card.
Thanks,
Vignesh
If you be afraid virus:
download a free antivirus (Avast)
or, connect your phone to your PC and display the card. PC antivirus scan your memory card.
Maybe it's not a virus .. card backup and re-format.
Maybe the data has become corrupt
Backup all important stuff from memory card to pc and format your sd card
well Vbose,even i face same kind of problems,nothing to worry.have a download a quickheal antivirus(30 days trial pack) and then you can scan your entire memory and then backup all ur necessary files and format ur memory card (remember don't use the "quick format " option.Store all your files in a separate folder and before u restore ur files into ur phone,rescan the folder and then proceed.if possible have a factory reset to ur phone after a proper backup
I have installed AVG anitivirus and scanned the phone. I didnt see any problem. And also the mobile is working fine I didnt see any problem.
When I am connecting the all Windows OS machine alone its showing floders like the short cuts.
Its working fine in the linux OS. Please advice wht would be the issue.
its shows shortcuts in mobile ???
Means you are connecting it in MSC mode....
try connecting it in mtp mode... settings > xperia > connectivity > usb connectuon mode > MTP
Its connnecting in MTP mode.. but it doesn't detect automatically... Auto detection is disable in MTP mode.
Further while in MTP mode I am not able to access memory card through Phone.
Is there any other solution ??
Make sure your windows media player is updated to latest version
Same goes for Java driver http://www.java.com/winoffline_installer
Try turning off firewall and antivirus..
Allow full access to pc companion in firewall
