touch issue
aakash07
touch issue
While charging the phone the touch is not responding well.touching any thing goes to double tap effect.is that a software issue or hardware?
10 REPLIES 10
profile.country.RO.title
_alexdon_
It depends on what charger you are using and the output of the adapter.
alexdon
aakash07
Ya that's correct. I check it
Thank you for the reply
_alexdon_
Anytime.
alexdon
loopy85
I have same problem and I'm using the charger that came with the phone brand new and tried another charger.how do I fix this?
_alexdon_
With which of the chargers you have this problem?
alexdon
loopy85
One is the charger that came with the phone which has a usb connection and the other is a normal charger
_alexdon_
And both make you trouble?
alexdon
loopy85
Yes they both do double touch on charge so I cant even type a msg properly or make a selection correctly whilst charging
_alexdon_
You should stop by a sony service:
alexdon
