I got my tipo on 22nd September. But only today i noticed that the drag or hold on the touchscreen never works! Be it for deleting home screen icons or the design unlocker thing. Is this a common problem. Also i am from kolkata,India.And it seems like no sony service centera are in my city. What to do?
It works on my tipo. There is an .apk file inside pack. Just copy to phone --> Install --> calibrate --> uninstall the program --> done.
Thank you so much....
I just went to get my phone vodafone with the apk you uploaded irondip worked perfect in 5 seconds ..... thank you very much! Now if that goes well the phone!! and once again Sony is incompetent we have to fix this users ....
GUYS, this is VERY promissing! I will get home and try, 'll let you know.
SONY, SAY SOMETHING...
@Nabeel
with Post #68 is this thread legitimately marked as solved. And Sony, was that so hard?
They are only to tell us to take the phone to sony not to offer solutions but what have you done your otti well you get a hole in the staff you've earned it! seriously thank you very much! :))))
the thanks should go to ironedip and blindshooter (no idea whether this is the same person) for posting the link to the solution.
Make a post published the solution of the problem because it really works simply install the apk with astro manager put the phone on a flat surface and works perfect .....! do the post!
Thank you very much for the link
Guys, I have created a thread for the patch:
http://talk.sonymobile.com/thread/57749?tstart=0
:smileylaugh:IT REALLY WORKS! THANK YOU IRONEDIP!!!!!:smileylaugh:
THE THREAD CONTAINS EASY STEP BY STEP
