Hi.,
I bought Sony Tipo on Sep 26 2012. From day 1 onwards i noticed the problem of ringtone volume reduction. When a call comes , it starts with louder tone and within a sec or 2 , the volume of ringtone is automatically reduced . What might be the problem? Is this a bug in device ?
Is the phone paired with any Bluetooth headset?
It almost sounds like the phone starts ringing then connects to the Bluetooth headset, this will reduce the ringtone volume.
If you're not using any headset I suggest that you try to reinstall the phone software using SUS.
I can't renistall the software. my phone was not detecting by holding the volume key down for few sec..
I had tried it several times& there was no use instead of taking it to customer support how can i solve this issue. please update
How did you solve the issue please update. When i switch off my mobile after few min, I could connect
Via usb then by holding volume key down for few sec nothing happens.. Could you update the steps properly
Hi, i have updated the mobile also, but still i am getting
the same issue, please help
For me to i update the phone. But the same problems occurs to me pls tell any solution
pls help us .............!
Hi All,
I found a small sollution,hope it will work,
If you are using Aircel SIM, please switch over to any other network and try
r u serious? bcoz i am using aircel sim.. let me try today and will feedback...
