hi guys... can anyone help me get themes for spiro and zylo mobiles ..... i am getting themes from various other sites but the phone says the themes are incompatible... so please if u could help ... thanking u
try the theme file in sywf.mywibes.com
blue_floral? which one should I download and wich phone model for the spiro shal I use?
thanks,
bn
try g502 themes. they work
try G 502 thrmes. they work
i hv used blue_floral in my j105 & w705 the theme works fine in both
i used the se hazel to get theames on my se zylo an worked great using the theames creator jus wanted to say thanks bud
I have a question about Spiro.
I downloaded the theme creator, chose z750 as my phone and created a theme. It works quite well, but there is no background in the walkman part and in the media part (where you can delete/edit/check your media files). (btw the walkman also belongs to the media)
I opened the theme in xml format within the creator and and inserted the line manually that was needed:
I saved the xml file, but this line was deleted from it. And the interesting thing is, that when I opened an original theme (Samba.thm) that I copied from the phone itself this line was not in the xml again (but I know that it is there, because I previously opened the theme with notepad, and it was there).
I also tried to edit the theme in the notepad. In this case the line was not deleted, but the phone could not use the theme because of an error (checksum).
Any suggestions? (I also tried to edit the theme with notepad++, but it created an error again)
Thanks for the advice, but my aim was to create custom themes for myself. Actually the problem was already solved
hmm? when my zylo was working g502 themes didnt work. in the end i used one of se's themes.
don't know why zylo seems to reject every non-se theme you throw at it.
