hi guys... can anyone help me get themes for spiro and zylo mobiles ..... i am getting themes from various other sites but the phone says the themes are incompatible... so please if u could help ... thanking u
download themes of the old fons like w995,w595 as these are easily and widely availaible , just make sure that the fon whose theme u r searching has a resolution of 240x320, now open sony ericsson thems creator in edit themes mode and select yari as your phone , then open the downloaded theme , it will ask you to convert the theme to newer version , click yes , then after a bit of customisation on your own or even without that save the theme , then transfer it to the fon, in this way , your themes will work and you will have a great variety of themes too
chose yari as the fon there , both of them work almost on the same platform , atleast there themes are of same version . chose yari as the fon and create the themes , the themes will work, i do it like this only , till now i am able to customize everything except that i cant add a flash menu , though i have added it but on transferring to fon it doesn't display the custom menu , it would be a great help if anyone could tell me how to do that
Ok.
after trial and error with the Themes Creator
downloaded from:
http://developer.sonyericsson.com/wportal/devworld/technology/themes-creator/overview?cc=gb&lc=en
I selected the Sony Z750, instead of the missing Spiro model a.k.a w100i, and the themes I created worked fine
Hope it helps,
good luck
Spiro also works wiht G502 themes.
hey, thanks guys.Now I can change the damn theme like other models.Z750i themes worked well except that the animated wallpapers aren't supported it seems.No gif wallpaper can be used which is confusing because on the official spiro page, it lists Wallpaper Animation as a feature!!
How come this phone doesn't animation of any sort (themes and wallpapers wise)?
well, it's a Sagem. nothing good can be expected from it
I didn't buy Sagem tho.This IS a Sony Ericsson branded phone, that's it.And the official specifications states Wallpaper Animation is supported.So it's a problem/bug that needs to be sorted out ASAP.
well, tbh you did. it's Sagem phone with SE branding
So basically you are trying to say SE fooled us all, right?
firstly, they fooled themselves when they thought "hey, it MIGHT be successfull!"
