T3 phone won't stop vibrating
Waltermq
Hello, at around 4am this morning my T3 started to vibrate and I could not turn it off for the life of me.  When I changed the screen black out to 15 seconds the screen turned off and now will not turn on. I have tried the various combinations of power button plus volume buttons to no avail.  It has now been vibrating for 3 1/2 hours and was at 25% when this all started.
Any Ideas?
5 REPLIES 5
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
alexdon
Waltermq
My phone finally died, when I connected it to my computer in an attempt to back up, it immediately starts to vibrate but will not connect to PCC.
_alexdon_
But isn't the force shutdown option working?
alexdon
yankeeee
try to charge with Force shutdown if it vibrates
Power button and volume up
and try to remove the screen protector
Connect your phone to a wall charger, press and hold power and volume up for 10 seconds, let it charge for two to three hours, then repair it with PCC
