stamina problem
danial1198
stamina problem
Hey, previously I had make a post about my stamina mode have problem. eco mode controller had been replaced by Extended standby Mode control and I have updated my phone to 4.3 and the update still not solves the problem. Hope Sony could fix this problem
8 REPLIES 8
Rickard
Xperia SP should have Stamina mode and not extended standby so that sounds very strange. What options do you see if you go to Settings -> Power management?
danial1198
Stamina mode, low battery mode, location based wifi. FYI my sp had an eco mode controller but suddenly it changed to extended standby mode control.
Rickard
Are you talking about the list of apps under Settings -> Apps -> All?
What happens if you enable Stamina under Settings -> Power management? Do you have any problem using it? You can test if it works by turning off the display, wait 15 minutes and then send an email or a message on Hangouts to the phone.
danial1198
Yes eco mode controller should be under settings > apps>all but it had been replaced by extended standby mode controller . After it has changed I enable stamina.mode and it seems to drain battery more quickly than I have stamina.mode off
Rickard
That's very strange. Could you please check the list of apps again when the phone is set to English (United Kingdom) under Settings -> Language & Input -> Language.
JTLtd_
I checked this as I was curious..
I'm running 4.3 in UK language, in Apps > All, mine shows as Eco mode controller (324KB)
danial1198
Problem solved it changed to eco.mode.controller after I change it to English UK language but mine is 316 kb
Danial-mach1
Leader
Mine is 324 too
So you clear cache and data..force stop and reboot your phone
But after for some time standby time that showed in battery usage page may inaccurate
