That's quite interesting, what happens if you now try the software repair process?
If it fails, then I can only really advise that the handset be sent to a service agent for repairs. That can be done by taking it back to the place of purchase or contacting Sony Mobile Customer Care from within your region.
I have a link in my signature below that will supply the contact details.
Have you tired performing a system repair using PC Companion
You had the same issue back in February
http://talk.sonymobile.com/t5/Xperia-SP/sp-not-working-wont-turn-on/m-p/944919#M35047
Please don't create duplicate posts as its consider SPAM
I took the liberty on merging the posts as it's the same issue that it seems it was never solved.
