I can use screenmirroring with my Samsung phone and tablet, older than my Sony phone. But when I start screenmirroring with my Z1 compact, then connection dialog opens both on TV and Z1, but terminates automatically with message, that TV does not support HDCP. As i understand, HDCP is a protection, wich allows to run DRM-encrypted media. And my TV should be able (and surely is able) to stream it.
I installed an Lollipop update to Z1 yesterday and hoped that now is this problem also solved but no...
How can I use screenmirroring with my Z1 Compact?
Your phone HDCP version is 2.2, and seems like your TV and Samsung phones are using an older version. This leaves you with 3 options:
- Use a fully compliant HDCP 2.2 mirroring device, I suggest Chromcast dongle so you don't have to trade your TV.
- Use a custom ROM that allows disabling HDCP check, I reckon Cyanogen Mod does allow this in Developers Settings.
- Change your TV to a fully compliant HDCP 2.2 one.
Check this post for more info:
/t5/Xperia-Z3-Z3-Dual/how-to-disable-HDCP-check-in-z3-dual/m-p/973941#M14635
Thank You, I hope it helpr. Soon we will see
