Sony liveware manager update problem
Hi, my xperia arc s is facing an update problem in the liveware manager. The current software version in my phone is 3.2.7 but whenever i try to update to version 3.3.10, there show me this message. 'Package file was not signed correctly. Uninstall the previous copy of the app and try again.' I cant uninstall the app as it is a built in app. Please help. Thanks.
6 REPLIES 6
Sam
Legend
Legend
Are you updating this via the Play Store?
also having same problem .
@sam i've updated via google play store
Sam
Legend
Legend
If you go into the Applications section of settings and tap on the application, which version does it say you have?
Sam
Legend
Legend
@NightRequiem this is the same version as what I currently have without any problems. In this circumstance it would be worthwhile running a repair via PC Companion:
and install it on your PC.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connectionn steps
ezhikov
i have 3.3.10
kathymay
I have this exacted same problem  and because of t it is not letting me connected my smartwatch.
I have done everything you said to do and it has taken me ages and wiped my hole phone but I am still having the same problem?
