Hi Sony Team,
Hope you are doing good,
I own a Xperia Arc S LT18i, i bought it with Gingerbread, it worked superb with all its features.
A week back, i upgraded it to ICS using SUS. It started working little slow post upgrade which is accepted upto some extent.
The major problem is with bluetooth, now when i connect my phone with Car bluetooth (which is also of Sony WX-GT99BT) the phone keeps on restart loop, it use to work fine, before the upgrade.
The only way to stop restart is to remove battery and then reload the OS. Its unable to go in safemode as well. Otherwise the Bluetooth works with other ICS phone (tested with Micromax A91, Android 4.0.4, Kernel version 3.0.13, build LWDEB02.1.0_M11).
Please suggest. Let me know if you require any logs from the phone and i shall provide the same.
Model no; LT18i
Android Version: 4.0.4
Baseband version: 8x55A-AAABQOAZM-203028G-77
Kernal Version: 2.6.32.9-perf (BuildUser@Buildhost#1)
Build no: 4.1.B.0.587
This issue has been discussed before. Please use forum search tool to find previous threads.
