I have an issue with Neo V. Some times I am facing issue when connecting to an incoming call. I do not have any other option than restarting the phone.
Details: I received call from my friend, when I accept the phone and drag the slide it says connecting to that person. But the person was speaking and he could not hear my voice. This kind of issue happend to me 5 to 6 times every time I need to restart my device.
Can u pls look in to this and provide an fix for the issue.
Rgds,
Babu
I'll recomend to repair your phone using SEUS
make sure that you backup everything before hand
if the problem continues after that, it might be a network issue or the SIM card
1) backup everything then
2) use SEUS to update your phone
2)
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
1) Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
My Phone Explorer
https://market.android.com/details?id=com.fjsoft.myphoneexplorer.client&hl=en
Other methods on how to install the Backup & Restore app and/or other apps that are stored on your SD card
1st Method
How to install it
You need to
download the app on your computer, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
2nd method
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
3rd Method
BOX and upload the apks from any computer
install the App on your phone -> open BOX -> tap on the app -> install it
4th Method by far the easiest
an even Easier alternative
download the app, transfer it to your SD card
Download Apk Manager
https://market.android.com/details?id=com.magmamobile.app.apkinstaller&hl=en
open "Apk Manager" and voila select the apps that you wan't to install
if you want to manually update your phone to the latest firmware this is how
Xperia Neo V MT11i 2.3.4 update 4.0.2.A.0.62
http://talk.sonyericsson.com/thread/30938
check your device if the the microphone is mute during the call.
if you are using a protective case, make sure it's not blocking the mic
