xperia pro camera flash problem
cloudstrife1ph
shots in the dark or low light conditions retains a ring of light on the side where the flash is. because of this, it's brighter on that side and you know that it's the burst of light from the flash. i don't know if this is a design flaw thinking that the flash-lense distance should be a bit more nearer or a software problem which causes a delay with the coordination of the flash and the lense. i'm also having a hunch with the plastic film protector at the back too as it possibly scatters the light from the surface that's why this happens.
anyone here experiencing the same thing?
9 REPLIES 9
can you upload some pictures so others can compare?
cloudstrife1ph
just a comparison from my n900
low light
from a dark area
from my xperia pro
low light
from a dark area
as you can see, there's always a whitish light on the right side of the photos from my xperia pro. i don't know if the skinomi is causing the light to scatter or the lense-flash distance as it's farther compared to my n900's or a software issue of a possibility of a delay from flash/lense...
are you using a protective case?
cloudstrife1ph
like otter box, crystal case and the likes? nope!
just the skinomi transparent plastic film to prevent scratches...
does that cover the back of the phone either
1) the camera lens?
and/or
2) the flash LED?
cloudstrife1ph
no. there's an allotted holes for those.
i can't disregard the fact that skinomi might possibly causing it as i haven't tried taking shots before i put it. it's my habit of putting skinomi before using my phones to avoid oil and smudges...
but still, it could be the other two..
you can backup everything and then repair/update your phone, just to narrow down the issue if its software or hardware
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
Backup everything then update with Update Service
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
An easier way to install the Backup & Restore app
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once  you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
or
cloudstrife1ph
thanks for the help uliwooly.
it took me just now to try taking pictures without the back cover. i found out that it's the skinomi doing it. light is being scattered and bounced off on the surface between the flash and the lense...
I knew it Dizzy_Face Make sure you mark theCorrect Answers & Helpful Answers so other users can find look up the Correct and Helpful answes if they have the same issue
