I'm using the google translator pardon my redacccion
my first topic in this forum
well for many years I have always been people who always chose the brand ah sony ericsson and so far am loyal to sony xperia
there's something I've noticed I hope you can get to take into account because for me and for you I think is absolutely important technology I like it I set some simple things.
sony xperia speak about the truth that I put as much thought asu software development
Cpu: Here's something that seems true ami wrong because? if you realize processor speeds are very short for example 345mhz, 500mhz, 700mhz, 1000mhz what note is that long delay occurs in the terminal however if you put different speed processor works even better with more battery consumption lower eg 100mhz, 180MHz, 270MHz to 1GHz so on for instance
kernel: here I also found another great touch, speeds between sectors O block as used in the kernel are worth 128kb since they launched xperia x8 to the latest uses this value via a script in the .sh extension I tried even 200000kb which team work faster without noticing processor interrupts oh sounds oh delays in the terminal are in the age of technology to use that value 128kb is something that is simply regrettable please are sony xperia
Data; This is another problem with this section is a .xml file whose structure's detention should add more applications to the device to be faster
system: good here that I can tell there are many things to change one of them is the app_process parameter that is responsible for launching the servicion should cut those services and so I have knowledge are not needed just take up memory that truth is wasted much
only give my opinion as a user knows the xperia range as I am true to sony should improve other things make the device more agile use less memory partitions leaving more free devices hopefully this speeds take into account my opinion and I send a big hello from mexico cabo san lucas am a member of the xda-developers community
Also as a member of XDA I ask if you know this to be a Sony specific development or Android on the whole, If this is Android then you need to pass this onto Google and if it's just Sony and can show proof then I will forward this onto the developers but without proof then it will go no further
if you know but now I wonder how hard it is combiar one value by another of smaller to larger tell me how hard it is because the open source kernel does not specify a value 128kb
developers that modify the kernel do this for them is very easy but for developers sony xperia difficult is it?
here my tests
