After disabling "Show Notification" for apps on SD card, reboot the phone, this setting will become re-enabled. It seems the setting does not stick for apps on SD.
I've tested these steps but no luck:
- disable it, move it to SD, reboot.
- disable it, reboot, move it to SD, reboot.
- move it to SD, disable it, reboot.
Not sure if this is a bug or limitation of Lollipop. I'm using 5.0.2 on D6653 (build # 23.2.A.1.62).
Anyone has a solution or workaround for this? Thanks.
I'll test it, could you share which SD card are you using? class, brand, etc.
This is what printed on the SD card.
SanDisk
Ultra
32GB
Micro SDHC I
(10)
Are you not seeing the same problem that I have?
Nope, I have not tested with another SD card. This SD card doesn't look like faulty, because it has no problem on both Mac and PC, and I'm running apps on this SD without problem. Repeat: the problem is just "Show Notificaiton" setting not sticking for apps on SD.
Please read this whole thread:
/t5/Software-Updates/Apps-moved-to-SD-card-still-reserve-space-in-internal-storage/td-p/956195
This apps to SD is a limited function.
@alexdon wrote:Please read this whole thread:
Thanks for the information. Here is my conclusion based on that discussion: It is not worthwhile to move apps onto SD, no benefits.
This "Show Notification" setting stickyness problem is not solved, but no need to look further, life is easier by keeping apps on system storage with current version of Lollipop.
