I have finally rooted my phone after stumbling upton low internal storage although i have a 32GB SD card, i would like to know what partiton size would i need to create to use the link2sd or app2sd so i cant move my apps over, i need to create another partition, what would you suggest i should create for a 32gb, 1gb or 2gb, or higher?
any help would be great.
I moved this thread to concerned sub forum. Hopefully you'll get some help here otherwise XDA might be worth checking as well.
what method did you follow to root your phone ?
I used SuperOneClick, i was worried about rooting my phone and it took me nearlly a month before i came up with the idea to just do it, i'm glad i did, it was just the matter of installing superoneclick, plugging in the phone via usb into the computer and pressing 'root' within a minute it was rooted, it installed the 'super user app' which then you know it's done, i'v never rooted a phone before but now i'm happy i did, i can finally move apps over to sd which i couldnt before, also i decided to go with 2GB partition as then i have plenty of space for all my apps to go over using link2sd and the rest 28GB can be used for my xperia play games.
can I use it to xperia ray with ISC?
Sorry i can't help you with that, maybe you could type it in google and see if anybody else has managed to do it, or maybe someone here will advise you, post it in the xperia ray section about rooting, i'm sure they will help you with that.
