guys i have updated my xperia m2 dual to kitkat version since then i am experiancing the problem, the device shows the warning message "sd card damaged format and reinsert the card" but the problem remains even after formatting the same card or inserting a new one please help me with the issue
So have you tried to format it while connected to your computer?
In this case,try another microSD,yours might be damaged.
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable.
Hi rmclaw,
same problem with me
Did you find any solution?
OK.
I think my SD card: Transcend 16GB class 4 is giving problem. tried with same type with 2GB mem card, its fine. no issues till now.
