Hi @Cmrba
If in safe mode everything works ok, there is an app that is creating this issue, but you can uninstall one app and check if this problem is resolved after doing this. Keep us updated please.
Hi @Cmrba
I don´t think that there is a problem with your video recorder, as in safe mode everything works ok. I´m at disposal for any question.
i have a problem onced as i cannot record video.
after checking in safe mode the same problem persist.
what i do is ;
1 go to google settings
2 go to search & now
3 go to voice
4 go to "Ok Google" detection
5 from the menu look for "From any screen" and disable it or disable the "Ok Google" detection.
this usually will do the trick.
hope this can help.
cheers
Thanks @jonathanjustin85!!!!
I did exactly this procedure and now Snapchat is working for me!!! Thank you SO much!!
(It seems a little bit akward that "ok google" impacts snapchat negativelly... anyway...)
