screen lock timeout
screen lock timeout
I have an Arc running Androis 2.3.4.
I have an issue with the screen lock and wonder if other have seen it.
i have anabled a pin passowrd. However, the Arc does not ask me for the pin everytime the screen timesout. i can simply unlock with the slide. Only after the phone sits blanl for a 15 or 20 minutes, it ask me for the pin.
I see no option to change or control the time between screen going out and when the pin is required.
any ideas?
17 REPLIES 17
I was thinking about that right now, I would suggest that you backup everything and then repair your phone with SEUS then delete mcafee
Do you think McAfee is the issue?
Also, sorry, what s SEUS?
Thanks!
1. you don't need mcafee
https://market.android.com/details?id=com.wsandroid&feature=search_result#?t=W251bGwsMSwyLDEsImNvbS5...
check all the permisions, but yeah just backup and repair your phone it should work fine after that
2 SEUS = Sony Ericcson Update Service
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
I did a clean install and repaired. The pin password works as expected until I enable the Activesync corporate email. After that, it goes back to the behavior I described earlier. So this may be related to the way Activesync policies are set up. My best guess!
Thanks.
Indeed that's the problem, I'll look into it
I removed the stock email program from exchange switch to Enhanced Email. This completely fixed the issue.
Also Enhanced-Email is a great email program.
I don't think using the Enhanced-email is the solution. As I mentioned on the other thread, this is definitely the problem on Sony Ericsson phone, or at least on the Xperia Arc S that I have.
I have the same setup on Motorola Milestone and Milestone 2, including the same Exchange setup. And it does not matter how long I keep the screen locked, I always get the unlock pin displayed after sliding the unlock bar. On my Xperia Arc S, with the exact same setup, I have to let the screen locked for a long time (possibly an hour or so - I am not sure) to have the unlock pin displayed.
I am using Xperia Arc S with build number 4.0.2.A.0.42.
Sashki
I have the same problem on my Xperia P. And I don't want to buy Enhanced-email app just to testing is it work or not.
