Helloo every one i got my new z3c and i was very happy but when i saw that the animations are not smooht i got one galaxy s5 and compare it and the galaxy s5 is much more smoother if i scrol in menu home screen everywere i scroll. maybe you know if there moves a light in the night and has a stripe behind it it is the same with the srcreen if i scroll you see stripes the display is good but i want to ask if this is normal ??
Which animations, Like the live wallpaper or something else? and if you have lines down your screen then are you able to take a photograph of this and post the image here?
Are you referring to the home launcher while moving through different panes?
it is just in every screen every move i do in the z1c it was so smooth every thing but in this one it lags a little bit and there is a kind of light effect on every screen every time i move it is just very annoiyng pffff did i reset but not helped i dont know how to explain but the easy way to tel is if you move a light there is a kind of stripe leaving its is somthing like this very very very annoing sorry for my bad english
The only other thing you can do is to try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
As for the lines then visit a store and do a comparison and if yours is different then you would need to either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
i will do a reset if not good i go to a store and compare it and if still not good i will send this phone back to the place were i buy it
but anyways thank yyou for youre time and reply the only thing i can do is reset and compare cheers man
How about
settings > about phone > tap multiple times on build number > back > Developer options > On > transition animation scale
