Same old battery issue
alb8
After carefully following all posts here, still no reasonable comment on what makes the battery getting dray so quickly.
Please look at my case... I am having (just counted them) 22 apps disabled. The screen shot aas you see is made after full charge with phone OFF, and then leaving the phone unattended for nearly 6h..Screenshot_2014-07-27-11-41-08.png 10% is far too much for standby, isn't it?
14 REPLIES 14
daverawle
Try "uninstall updates" for google play services. The phone may be a little less smart but mostly only for google stuff. It's just google enhancing their vending experience at the expense of your battery.
Dave
daverawle
Is there a fault with the battery or am I missing something Try "uninstall updates" to google play services. It's just google enhancing their vending experience at the expense of your battery. Dave
vkuchhal
I am also getting a very low battery backup, I am using greenify will all apps hibernated and with only 2 hours of game play and using few apps and wifi on for sometime , the phone hardly lasts for 1 day.
May be should have gone for any local brand brand phone like micromax or xolo .
Tags (1)
zagna2
Tell me one think. Regardless of battery draining, how much time you need to charge your phone from less than 10% to 100%?
spixel
I have this exact same problem for 7 months. Sometimes standby drain is okay but most times its like this (really crap) even when the phone is reset to factory defaults and nothing installed.
Turning wifi off makes no difference at all, I found the only way to improve it to restart phone and avoid playstore.
Having said that, yesterday was the only day since I got this phone that I could use playstore then let the phone standby without the drain starting, it remained at around 1% per hour. I don't know if this was a fluke or perhaps a play services update was released.
This is what I recommend to get bests standby time on SP
#1 Disable Stamina mode, this does not help at all. If anything makes battery life worse, unless your phone is full of active apps in standby
#2 Restart phone often especially after recharge and don't update apps from playstore unless you have to
#3 Leave all default apps enabled. I tried this, disabling 1 by 1 but it never helped. Yesterday when the problem seemed resolved, I had 0 apps disabled.
#4 Say a prayer at night Slightly_smiling_Face
