Rooting Live with Walkman (WT19i) with locked bootloader using Flashtool on MacBook
ManggApple
Hi, good day. Noob here. 😆
I'm going straight to the point. I have already tried rooting my Live with Walkman about a year ago, but then I experienced a boot loop. I fixed my phone using Sony Bridge, it was brought to life again. But I suspect it is the reason my Live isn't rooted anymore, or made it not properly rooted (the root checker app said it isn't properly rooted)
Now, I wanted to root my phone again (with bootloader locked) but I forgot how to do it. I have Flashtool, and it is what I used to root my device before.
Here is the log that I get whenever I try to press the pad lock icon that says "Root".
15/054/2015 12:54:10 - INFO - <- This level is successfully initialized
15/054/2015 12:54:10 - INFO - Flashtool Version 0.9.10.1 built on 2013-01-09 22:58:57
15/054/2015 12:54:10 - INFO - You can drag and drop ftf files here to start flashing them
15/054/2015 12:54:12 - INFO - Device disconnected
15/054/2015 12:54:23 - INFO - Device connected with USB debugging on
15/054/2015 12:54:24 - INFO - Connected device : WT19
15/054/2015 12:54:24 - INFO - Installed version of busybox : BusyBox v1.18.5 (2011-07-18 07:43:28 PDT) multi-call binary.
15/054/2015 12:54:24 - INFO - Android version : 4.0.4 / kernel version : 2.6.32.9-perf / Build number : 4.1.B.0.587
15/054/2015 12:54:27 - INFO - Device connected with USB debugging off
15/054/2015 12:54:27 - INFO - For 2011 devices line, be sure you are not in MTP mode
15/054/2015 12:54:30 - INFO - Pushing /Applications/FlashTool.app/Contents/MacOS/./devices/WT19/busybox/1.20.2/busybox to /data/local/tmp/busybox
15/054/2015 12:54:30 - INFO - Pushing /Applications/FlashTool.app/Contents/MacOS/custom/root/subin/Supersu/su to /data/local/tmp/su
15/054/2015 12:54:31 - INFO - Pushing /Applications/FlashTool.app/Contents/MacOS/custom/root/subin/Supersu/Superuser.apk to /data/local/tmp/Superuser.apk
15/054/2015 12:54:34 - INFO - Please look at your device and click RESTORE!
15/054/2015 12:54:34 - INFO - You have 60 seconds to follow the restore advice
15/054/2015 12:54:35 - INFO - Running adbrestoreexploit
15/055/2015 12:55:39 - INFO - Root hack did not work. Cleaning hack files
15/058/2015 12:58:25 - INFO - Device connected with USB debugging on
15/058/2015 12:58:25 - INFO - Connected device : WT19
15/058/2015 12:58:26 - INFO - Installed version of busybox : BusyBox v1.18.5 (2011-07-18 07:43:28 PDT) multi-call binary.
15/058/2015 12:58:26 - INFO - Android version : 4.0.4 / kernel version : 2.6.32.9-perf / Build number : 4.1.B.0.587
I want to know, what the heck am I supposed to do with the "Please look at your device and click RESTORE!" if there's no RESTORE on the screen? Haha. And if there's something I haven't done, or I am supposed to do, please let me know.
And please.. Please reply asap. I would appreciate any help. THANK YOU VERY MUCH IN ADVANCE! Grinning_Face
EDIT: Alright, I think the backstory's a bit unclear. That doesn't really matter, so... Yeah. PLEASE HAAAAAAALP..!
SECOND EDIT: I tried following this thread: http://forum.xda-developers.com/showthread.php?t=2118343 I am having problems on where to put the kernel. Where can I see the firmware folder here on Mac's Finder? THANKS!! Grinning_Face
NEEEEVER MIIIIIIND!!
http://forum.xda-developers.com/showthread.php?t=2399464
That'll help. xD
Samuel1
Hero
I'm glad to hear everything worked out for you!
Best regards,
