I need some help.. I got my SE LWW on December, after a month of using it, there is this touch button problem. When I touch the right button from the home screen, the T9 virtual keyboard appears instead of add, wallpaper, theme, and setting. What should I do? What is it happening?
backup everything then repair your phone with Update Service, if its a software issue, it should be resolved
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
My Phone Explorer
https://market.android.com/details?id=com.fjsoft.myphoneexplorer.client&hl=en
An easier way to install the Backup & Restore app
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
or
Latest update (manually update)
Live w/ Walkman WT19i 2.3.4 Build number 4.0.2.A.0.62
http://talk.sonyericsson.com/thread/30983
thanks for the response but I already have the latest software for SE LWW since december.
yes I know, but this is to repair the software, just try it
Try to repair the software even though you already have the latest one.
- Remove any protective film/case you might have on the phone. If attached wrong, it might cause issues like this.
- When charging the phone, the touch sensibility can appear strange and less accurate.
