i tried to repair it..again bec after alot of aplication i installed i jus removed them ...
uhmm it happend after it asked me to restart the phone removing usb then holding the back buttton..
now its hanggin at that part after it detected the SCEm sumting USB...
any info about this... this happed after PC comp updated
re-install Update Service -> restart your PC then run SEUS
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
or this
Xperia X8 2.1.1.C.0
http://talk.sonyericsson.com/thread/29293
at the 2nd step... plugging your usb then holding the back button..
it detects the SCEM usb then there it lags the whole pc hangs need to force restart
last time its really fine
i did also tried it but it seems it still hangs at the same said part...
any otherway?
restart your computer then press F8 then select Safe Mode
then try SEUS first
it hangs when it detected SCEM from the unit , , , is it from micro sd? or from phone?
install PC Companion then restart your computer that should find your driver, or connect your phone on flashmode (you already know how to do that, its like when you connect your phone to SEUS) your computer will start looking for the driver, make sure to turn off your firewall and antivirus
it hangs on SCEM driver is detected..
i tried using safe mode it works thanks :smileygrin:
