1.how to increase the ringer volume in my xperia ray?
because it has only max 7 pts but for media it has 15pts
my kind request to SE if they do some aesthetic change in their products it would
be more sucessfull. bcoz most of the SE products has it's speaker/ringer at back instead of this if they had at side faces it would be more effective.
2.Can i remove PC Companion folder in my SDCard since it's occupy space. if doing so any pblm will occur?
3.when ever i login into facebook in my mobile the first sync contacts screen appears, every time i select don't sync and go with done button, it's annoying for me. is there any way to do settings permanently or do not show this msg again option?
4.tamil font's not appearing in the facebook
5.is there any shortcut to directly access the call log?
the easiest way to manipulate all volumes is with this app
QuickSettings
https://market.android.com/details?id=com.bwx.bequick&hl=en
2) yes you can, just go to settings -> sony ericsson -> uncheck install pc companion
3) are you using the
a) facebook app?
b) through a browser?
c) did you synced the account w/ your phone (settings -> accounts & sync)?
4) you can NOT change the font in Xperias, you can download a messaging app that will allow you to modify the font within that app, but not the system fonts, same goes for the browsers etc.
http://talk.sonyericsson.com/message/151612#151612
5) there are widgets for that but not quite shortcuts
on the homescreen press MENU -> widgets -> favorites and call log
or
install this widget Life.contacts beta
sorry yar just now i check my background sync acc. i didn't sync my FB yet.
so what was the issue with 3)?
Hey if I add my acc in manage acc section, it always shows me in online
If I logout a msg appears that ur facebook data will be removed
Then I check it in acc section. My facebook acc not exist.
I need my facebook acc to exist in that section provided that I can able
to logout just like a gtalk.
I'm assuming you are using the FB app, once you go to chat it will show that you are online, but press MENU -> go offline
