Pros and cons of. 207
LukaLuxXD
A simple topic, share your pros and cons of the new update Grinning_Face
38 REPLIES 38
daverawle
@Thommo
Which country has the .207 firmware or which network - All I see is .205
Edit - Greece - A regional firmware which is branded I also see a lot of T-Mobile branded firmware so these will be modified generic firmware preloaded with what you call bloatware there is no difference between the .205 and .207 other than the pre-loaded apps
WHAT!
Are you saying you are not aware of version .207? Why bother to reply if you are so under-informed?
If anyone can answer the original question I would appreciate it
Dave
J0a0
I have 207 over OTA and till now I don't see any differences with 205! Nothing... For me everything is the same... Same bugs...everything!.. Sony on the best Slightly_frowning_Face
Thommo
Genius
Read my reply again Dave
It clearly says Edit: I then go on to explain that there is no difference between .205 and .207 other than it been a network variation and a branded firmware
MCTan1953
info 207.jpgTo see which countries has the .207 - just download this small simple tool and you can see for yourselves.
http://www.xperiablog.net/2014/02/20/xperia-updatechecker-tool-helps-you-check-on-that-firmware-upda...
daverawle
@Thommo
Interesting, is that official, where did you get that information?
Dave
Thommo
Genius
Years of experience
or you can use the above program which many of us do and see - All the .207 firmwares are for networks and also this firmware isn't listed on PTCRB also indicating that it is a network variation and branded
MCTan1953
shahi
Why its not coming to unlocked Xperia SP devices ?!!! it released just for operators Slightly_frowning_Face
Tags (1)
daverawle
@MCTan1953
Thank you:smileysmileywink:
Dave
Grey
We dont have any official changelog for 12.1.a.1.207 so I write one after one day.
- More Ram than ever
- The best battery backup so far. (it took me 30 minutes from 2% to 1% battery with wifi on while watching HD youtube videos
- Better wifi signal: at the. 205 update in my room the wifi signal was one or two. Now its full and the HD videos didn't buffer at all.
- While taking fotos focusing is now fast and perfect
- just a little bit overheating. In. 205 after 30 minutes HD videos my phone was about 40 degrees now after 30 minutes HD videos I didnt feel any. But when I tried to transfer my datas to my sd card it says memory stopped working (problem solved) but overall I think it's the best Jb ROM. As fast as. 205.
