Problems sending receiving files via Bluetooth
jadov
Hello,
I'm facing a problem with my new Xperia X10 Mini pro. I CAN'T SEND/RECEIVE FILES VIA BLUETOOTH.
I can pair my phone to another phones but it's impossible to establish a connection and send files via Bluetooth.
Does anyone have a solution for this issue?
thank you.
jadov
10 REPLIES 10
hi bernal17,
as for your HBH-DS220, did you make sure you put it into "pairing" mode? Simply switching on is not enough. Usually you put a BT headset into pairing mode by switching it on and keep the power button pressed until you get either an audio notification (like a beep) or the LED starts blinking red/green. Then you should be able to pair the devices.
Good luck!
Martin
