Problem with themes
Akshay_12
Problem with themes
Is anyone else experiencing problem with themes?
I downloaded "woody" theme from sony select. It seems like whenever i apply this theme my phone fails to restart and gets stuck at boot animation screen. So I have to repair my software after this. I repaired my phone 4 times before figuring out that theme was creating the problem, earlier i thought it was a bug in firmware.
14 REPLIES 14
Mikito
I had the same you need to remove the sim card, then restart the phone . This works fine then then you change the theme back to the default one and then you can restzrt the phone with no probleme and insert the sim again. With the woody theme on it it reboots all the time when you restart the phone. Kind regards mikael
sepehrland
I have thesame on my V
Tags (1)
profile.country.RO.title
_alexdon_
You just need to apply a default theme and restart the phone.
alexdon
adibek
So i can't use Xperia dedicated themes on my SONY Xperia SP phone with SONY firmware ?? Why ??? Default themes are fine but maybe someone need new look using themes , where is the problem ???  themes are wrong ??? firmware are wrong ??? or something else ????
_alexdon_
After you restart,try to apply a modified theme.
alexdon
