Problem with themes
Akshay_12
Problem with themes
Is anyone else experiencing problem with themes?
I downloaded "woody" theme from sony select. It seems like whenever i apply this theme my phone fails to restart and gets stuck at boot animation screen. So I have to repair my software after this. I repaired my phone 4 times before figuring out that theme was creating the problem, earlier i thought it was a bug in firmware.
14 REPLIES 14
cestnico99
Woody working great here. Don'y have to restart to apply.
Download few themes and changing them with my mood of the day and no problem at all!
Sorry for you.
Akshay_12
Even i don't have to restart to apply the theme. But when woody is applied and i switch my phone off it fails to restart.
I read the reviews just now o google play and others are experiencing this problem too.
0009
Yes i am also facing some problems with both downloaded And stock themes. Whenever. I apply themes the wallpaper on home screen. Doesn't move with the homescreens but when I press both home button and small apps button side by side continually. 4 to 5 times then it sometimes starts working and sometimes. The whole wallpaper messes up like. A puzzle plz help
Akshay_12
i think factory reset should solve your problem. Just take back up of everthing you need and do a factory reset.
I did Factory reset and my phone is working great now apart from the downloaded theme part
0009
Back up on sd card or pc???? And factory. Resetting would. Delete 4.3 update. Or not????
Danial-mach1
Leader
Neither factory reset nor software Repiar will not rollback update to4.1.2
MDIHRANA
I had to give my phone a flash after downloading 2 xperia themes from play store. when i downloaded them my phn started to restart continuosly.
0009
Thanx. Dan
0009
And akshay
