Problem with Sony Ericsson Bridge for Mac
I installed the Sony Ericsson Bridge for Mac application, but impossible to use it.
It says something like "The application closed in an unexpected way" (I use a French language mac). Sometimes I can launch it for a few seconds though, but then still get the error message.
Details or error:
Process:         Sony Ericsson Bridge for Mac [415]
Path:            /Applications/Sony Ericsson Bridge for Mac.app/Contents/MacOS/Sony Ericsson Bridge for Mac
Identifier:      com.sonyericsson.Sony-Ericsson-Bridge-for-Mac
Version:         1.0.1 (3015)
Code Type:       X86 (Native)
Parent Process:  launchd [221]
Date/Time:       2011-12-04 11:47:06.470 +0800
OS Version:      Mac OS X 10.6.8 (10K549)
Report Version:  6
Interval Since Last Report:          2401390 sec
Crashes Since Last Report:           32
Per-App Interval Since Last Report:  104 sec
Per-App Crashes Since Last Report:   20
Anonymous UUID:                      FCDEC200-1C8C-4D5D-8972-EC766B9EB66C
Exception Type:  EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread:  4  Dispatch queue: com.apple.root.default-priority
45 REPLIES 45
NilsAndreasson
OK, sorry to hear that, but thank you for trying, it's invaluable input for the hard to find bugs.
I got two theories here, either an easy one or a hard one.
The "not so probable cause but worth a shot" is to delete supporting data:
In your "home" folder, goto Library->Preferences and find this file:
com.sonyericsson.Sony-Ericsson-Bridge-for-Mac.plist
If it exist, delete it.
In your "home" folder, goto Library->Application Support and find the folder
Restart Bridge.
However, the probable cause is that you got something in your iTunes or iPhoto library that causes Bridge to crash. Unfortunately there's not much to do about that right now, but I've filed a bug and will definitely look into it. If you're interested in helping out more, send me a private message with your email address.
Best regards
/Nils
Hi all,
Here is my global feedback on this issue:
- The software is still not working properly, it's a real bug. Many manufacturers make "bad copies" of their Windows software for the Mac version, it's a shame but it's a fact.
- BUT, after all, these softwares are completely useless with Android phones. We just need to copy/paste files in the Phone, when it's set to MSC mode in Settings/Sony Ericsson/Connectivity
So now I am fine, I just don't use the software, and simply plug the phone to my mac!
Regards
I have just got a Xperia Arc and also can't sync to iTunes on Mac(10.7.2), it worked better in the pre 1.1 release atleast that was my impression but now i crashes all the time during sync!
Really bad.
Also a note, the music selection method should improve, not just select one buy one or all I should be possible to select a "start" and select a "end" then sync!
Second if masstorage mode is a must(I read in the online help) then the software should tell the user that that, Apple software are easy to use so should SE be right!
Anyway I can help let me know so we get this fixed ASAP(innan jul gärna)
/michael
Dear All,
I'm also can't run this program too. Do any one know is it work fine now?
Thanks for your help.
I had the same instant quit problem with the Bridge for Mac software trying to connect an Xperia Ray to a PowerMac running OS X 10.6.8 (Snow Leopard) but I've just installed it on my MacBook Air running 10.7.2 (Lion) and it appears to be running fine there.
Hope this helps.
NilsAndreasson
Hi all,
we are working hard in trying to find the issues here, and I hope we have a handle on them by now.
We haven't been able to reproduce the instant crash issue, but thanks to the log from Lairyliam we got a fair idea of what the problem is. Unfortunately, I don't think there is a workaround for it at this moment, since it seems to be related to corrupted/unusual data in the iTunes or iPhoto library. michal_walker:s post seems to confirm that- (I don't think it's the upgrade, I think it's the fresh iTunes/iPhoto library that helped) Stay tuned for more info soon.
For the people who experience connection issues - the phone isn't recognized when plugged in or you get a connection error dialog, here are some workarounds to try until we get the next update is out:
Try disabling the Auto Start setting:
- In Bridge for Mac, goto "Preferences" and set "When a phone is connected to a computer" to "Do nothing"
- Quit Bridge
- Connect your phone and wait for a short while
- Start Bridge for Mac manually
(The key here is to connect the phone and wait a while and then start Bridge)
Try both connection modes
The phone can connect to the computer in two different modes: Media Transfer or Mass Storage mode. Both modes are supported by Bridge, so if one doesn't work, try the other.
- Make sure your phone is disconnected
- In your phone goto Settings->Sony Ericsson->Connectivity->USB Connection mode.
- Try both options (Media transfer mode or Mass storage mode) to see if one works better than the other.
And to mlaajanen:
You can select several by shift-clicking in the list and press "Mark selected/Unmark selected" in the upper right corner of the list (We are working on improving this UI....)
And no, Mass Storage isn't a must, you can use Media Transfer (I think this was a temporary limit for Android phones in the old Media Sync)
Also, could you please tell me a bit more about your crashes? You get application crashes while you sync? If you wouldn't mind could you describe in a bit more detail what is happening? Which version of the software are you using? Any particular media kind that causes the problems?
Regards
/Nils
I'm having the same problem as described above with my Xperia X10. I attempt to sync with an iTunes playlist, which it manages to do partially before quitting unexpectedly.
Now, every time I try to connect the phone the application will either do nothing, or show "Detecting phone..." for a while before going back to how it is with nothing connected. Now, when I can get it to detect the phone (which seems to be only on the first run after deleting preferences) and connect to it, pushing the "Sync" button causes it to quit. I've tried deleting preference files, reinstalling the application, various combinations of connecting the phone and opening the application, removing synced files and starting fresh... everything mentioned in this thread. I'd had this problem before and given up trying to use the program, but after seeing that an update was available (1.1(3023)) I hoped the problem had been fixed.
I know you're aware of the issue and working on it, I just thought I'd give you the details of my crash in the hope that it helps.
Details and system info are here: http://pastebin.com/yznHfPX5
Richard
Hi!
I have just got my new Arc S last week and apparantly, the Bridge is giving me problem. I had tried re-download from sony website 4 times and problem still persist. Once I click on 'Sync' button to sync music, immediately the program shuts down giving me this report:
Process:     Sony Ericsson Bridge for Mac [1597]
Version:     1.2 (3035)
Parent Process:  launchd [89]
Date/Time:   2012-02-04 22:05:15.899 +0800
Report Version:  6
Interval Since Last Report:      88602 sec
Crashes Since Last Report:       64
Per-App Interval Since Last Report:  32956 sec
Per-App Crashes Since Last Report:   48
Anonymous UUID:                  DE937788-9ED3-4D79-A8F8-C8003BEBDA93
Crashed Thread:  2  Dispatch queue: com.apple.root.default-priority
Application Specific Information:
*** Terminating app due to uncaught exception 'NSInvalidArgumentException', reason: '*** -[NSPlaceholderString initWithString:]: nil argument'
*** Call stack at first throw:
0   CoreFoundation                  0x98c976ca __raiseError + 410
1   libobjc.A.dylib                 0x965885a9 objc_exception_throw + 56
2   CoreFoundation                  0x98c973f8 +[NSException raise:format:arguments:] + 136
3   CoreFoundation                  0x98c9736a +[NSException raise:format:] + 58
4   Foundation                      0x95a8900d -[NSPlaceholderString initWithString:] + 105
5   Foundation                      0x95a9338c +[NSString stringWithString:] + 72
6   DeviceConnectivity              0x0010e33d +[DRMetaMP3Frame frameWithData:version:] + 1085
7   DeviceConnectivity              0x0010ea37 -[DRMetaMP3 parseData:] + 826
8   DeviceConnectivity              0x00108475 +[DRMeta metaWithData:] + 155
9   DeviceConnectivity              0x001051b6 +[DRFileUtils prepareToCopyFile:toFilesystem:] + 449
10  DeviceConnectivity              0x000d5c62 -[DRDevOpPrepareSyncFiles main] + 236
11  Foundation                      0x95a8bb5a -[__NSOperationInternal start] + 705
12  Foundation                      0x95b7c0bb ____NSOQSchedule_block_invoke_2 + 119
13  libSystem.B.dylib               0x94db6a24 _dispatch_call_block_and_release + 16
14  libSystem.B.dylib               0x94da8cf2 _dispatch_worker_thread2 + 228
15  libSystem.B.dylib               0x94da8781 _pthread_wqthread + 390
16  libSystem.B.dylib               0x94da85c6 start_wqthread + 30
Thread 0:  Dispatch queue: com.apple.main-thread
0   libSystem.B.dylib         0x94d82afa mach_msg_trap + 10
1   libSystem.B.dylib         0x94d83267 mach_msg + 68
2   com.apple.CoreGraphics    0x94271a6a _CGSSynchronizeWindowBackingStore + 139
3   com.apple.CoreGraphics    0x9426abd4 _CGSLockWindow + 5001
4   com.apple.CoreGraphics    0x9427160a CGSDeviceLock + 493
5   libRIP.A.dylib            0x98aae593 ripd_Lock + 62
6   libRIP.A.dylib            0x98aade90 ripl_BltShape + 599
7   libRIP.A.dylib            0x98aab247 ripc_Render + 377
8   libRIP.A.dylib            0x98aa8454 ripc_DrawRects + 622
9   com.apple.CoreGraphics    0x94270ec0 CGContextFillRects + 159
10  com.apple.CoreGraphics    0x942b3a4c CGContextFillRect + 32
11  com.apple.coreui          0x95877072 CUIRenderer::DrawWindowFrameDark(CUIDescriptor const*) + 4668
12  com.apple.coreui          0x95879c2f CUIRenderer::Draw(CGRect, CGContext*, __CFDictionary const*, __CFDictionary const**) + 5287
13  com.apple.AppKit          0x98fc2024 _NSDrawThemeBackground + 1157
14  com.apple.AppKit          0x99083546 -[NSGrayFrame drawWindowBackgroundRect:] + 535
15  com.apple.AppKit          0x98fc6553 -[NSFrameView drawThemeContentFill:inView:] + 2288
16  com.apple.AppKit          0x9908302c -[NSGrayFrame drawRect:] + 71
17  com.apple.AppKit          0x98fbf6f1 -[NSView _drawRect:clip:] + 3721
18  com.apple.AppKit          0x98fbcdbd -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topView:] + 2217
19  com.apple.AppKit          0x98fbc34f -[NSThemeFrame _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topView:] + 265
20  com.apple.AppKit          0x98fb8c96 -[NSView _displayRectIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:] + 3309
21  com.apple.AppKit          0x98f1984b -[NSView displayIfNeeded] + 818
22  com.apple.AppKit          0x98ee2b64 -[NSWindow displayIfNeeded] + 204
23  com.apple.AppKit          0x98f1407e _handleWindowNeedsDisplay + 696
24  com.apple.Foundation      0x95a92484 __NSFireTimer + 141
25  com.apple.CoreFoundation  0x98c01a3b __CFRunLoopRun + 8059
26  com.apple.CoreFoundation  0x98bff3c4 CFRunLoopRunSpecific + 452
27  com.apple.CoreFoundation  0x98bff1f1 CFRunLoopRunInMode + 97
28  com.apple.HIToolbox       0x93622e04 RunCurrentEventLoopInMode + 392
29  com.apple.HIToolbox       0x93622bb9 ReceiveNextEventCommon + 354
30  com.apple.HIToolbox       0x93622a3e BlockUntilNextEventMatchingListInMode + 81
31  com.apple.AppKit          0x98eea595 _DPSNextEvent + 847
32  com.apple.AppKit          0x98ee9dd6 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
33  com.apple.AppKit          0x98eac1f3 -[NSApplication run] + 821
34  com.apple.AppKit          0x98ea4289 NSApplicationMain + 574
35  ...ony-Ericsson-Bridge-for-Mac0x00002e41 start + 53
Thread 1:  Dispatch queue: com.apple.libdispatch-manager
0   libSystem.B.dylib         0x94dbe58a select$DARWIN_EXTSN$NOCANCEL + 10
1   libSystem.B.dylib         0x94da9b8b _dispatch_mgr_invoke + 454
2   libSystem.B.dylib         0x94da8f59 _dispatch_queue_invoke + 163
3   libSystem.B.dylib         0x94da8cfe _dispatch_worker_thread2 + 240
4   libSystem.B.dylib         0x94da8781 _pthread_wqthread + 390
5   libSystem.B.dylib         0x94da85c6 start_wqthread + 30
Thread 2 Crashed:  Dispatch queue: com.apple.root.default-priority
0   com.apple.CoreFoundation  0x98ce2a37 ___TERMINATING_DUE_TO_UNCAUGHT_EXCEPTION___ + 7
2   com.apple.CoreFoundation  0x98c973f8 +[NSException raise:format:arguments:] + 136
3   com.apple.CoreFoundation  0x98c9736a +[NSException raise:format:] + 58
4   com.apple.Foundation      0x95a8900d -[NSPlaceholderString initWithString:] + 105
5   com.apple.Foundation      0x95a9338c +[NSString stringWithString:] + 72
6   ...inerobot.DeviceConnectivity0x0010e33d +[DRMetaMP3Frame frameWithData:version:] + 1085
7   ...inerobot.DeviceConnectivity0x0010ea37 -[DRMetaMP3 parseData:] + 826
8   ...inerobot.DeviceConnectivity0x00108475 +[DRMeta metaWithData:] + 155
9   ...inerobot.DeviceConnectivity0x001051b6 +[DRFileUtils prepareToCopyFile:toFilesystem:] + 449
10  ...inerobot.DeviceConnectivity0x000d5c62 -[DRDevOpPrepareSyncFiles main] + 236
11  com.apple.Foundation      0x95a8bb5a -[__NSOperationInternal start] + 705
12  com.apple.Foundation      0x95b7c0bb ____NSOQSchedule_block_invoke_2 + 119
Thread 3:
0   libSystem.B.dylib         0x94da8412 __workq_kernreturn + 10
1   libSystem.B.dylib         0x94da89a8 _pthread_wqthread + 941
2   libSystem.B.dylib         0x94da85c6 start_wqthread + 30
Thread 4:
Thread 2 crashed with X86 Thread State (32-bit):
  eax: 0x00000000  ebx: 0x96588585  ecx: 0xb0103000  edx: 0x0000003b
  edi: 0xa0760ab0  esi: 0x1856a290  ebp: 0xb0102a78  esp: 0xb0102a60
   ss: 0x0000001f  efl: 0x00000286  eip: 0x98ce2a37   cs: 0x00000017
   ds: 0x0000001f   es: 0x0000001f   fs: 0x0000001f   gs: 0x00000037
  cr2: 0x2ca92000
Binary Images:
0x1000 -0x6affb +com.sonyericsson.Sony-Ericsson-Bridge-for-Mac 1.2 (3035) <60C7616B-3944-3F07-98EB-5CF1AEDAED23> /Applications/Sony Ericsson Bridge for Mac.app/Contents/MacOS/Sony Ericsson Bridge for Mac
   0xcf000 -   0x120ffb +com.divinerobot.DeviceConnectivity 1.0 (1) <32F8D677-6D3A-3B13-9614-56249952E939> /Applications/Sony Ericsson Bridge for Mac.app/Contents/Frameworks/DeviceConnectivity.framework/Versions/A/DeviceConnectivity
  0x15a000 -   0x16dfff +org.andymatuschak.Sparkle 1.5 Beta 6 (313) <5DF2B8A3-560D-4500-6B85-4215644DE532> /Applications/Sony Ericsson Bridge for Mac.app/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
  0x17b000 -   0x230fe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <0B69B1F5-3440-B0BF-957F-E0ADD49F13CB> /usr/lib/libcrypto.0.9.7.dylib
0x1271d000 - 0x1272bfe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <07211458-FD06-9FEF-3DF4-2E5F0304D4BC> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x27700000 - 0x27784fe7  com.apple.xquery 1.3 (29) <50F6142C-7E17-D926-8D92-DD1ED86C3406> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) /usr/lib/dyld
0x90299000 - 0x9031bffb  SecurityFoundation ??? (???) <3670AE8B-06DA-C447-EB14-79423DB9C474> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x904b6000 - 0x904b9ff7  libCoreVMClient.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x904ba000 - 0x90535fff  com.apple.AppleVAFramework 4.10.27 (4.10.27) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x905e0000 - 0x90698feb  libFontParser.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x90739000 - 0x90876fe7  com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <2D31CC6F-32CC-72FF-34EC-AB40CEE496A7> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9087f000 - 0x9089bfe3  com.apple.openscripting 1.3.1 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x909d3000 - 0x90a26ff7  com.apple.HIServices 1.8.3 (???) <1D3C4587-6318-C339-BD0F-1988F246BE2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x90a27000 - 0x90a2aff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <4D766435-EB76-C384-0127-1D20ACD74076> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x90a2b000 - 0x90a61fff  libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib
0x90a62000 - 0x90ac6ffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x90b58000 - 0x90b92ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <6875335E-0993-0D77-4E80-41763A8477CF> /usr/lib/libcups.2.dylib
0x90b96000 - 0x90cc3ffb  com.apple.MediaToolbox 0.484.60 (484.60) /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x90cd5000 - 0x9110aff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x912ea000 - 0x91700ff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x9170a000 - 0x91710fff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x91711000 - 0x91813fe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <015563C4-81E2-8C8A-82AC-31B38D904A42> /usr/lib/libcrypto.0.9.8.dylib
0x91971000 - 0x919bafe7  libTIFF.dylib ??? (???) <579DC328-567D-A74C-4BCE-1D1C729E3F6D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x919bb000 - 0x91c04ffb  com.apple.JavaScriptCore 6534.51 (6534.51.21) /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x91c15000 - 0x91c62feb  com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <136BFA48-D456-B677-3B5D-40A6946C3A09> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x91c63000 - 0x91c67ff7  libGFXShared.dylib ??? (???) <801B2C2C-1692-475A-BAD6-99F85B6E7C25> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x91fe2000 - 0x91ffdff7  libPng.dylib ??? (???) <25DF2360-BFD3-0165-51AC-0BDAF7899DEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91ffe000 - 0x92009ff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <287DECA3-7821-32B6-724D-AE03A9A350F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x926d6000 - 0x92804fe7  com.apple.CoreData 102.1 (251) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x929e8000 - 0x92a25ff7  com.apple.CoreMedia 0.484.60 (484.60) <8FAB137D-682C-6DEC-5A15-F0029A5B226F> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x92a52000 - 0x92b95fef  com.apple.QTKit 7.7 (1787) <3B47A1A0-7AB5-C1C9-42DE-5993D1012D47> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x92b96000 - 0x92baafe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0x92bab000 - 0x92bdefff  libTrueTypeScaler.dylib ??? (???) <0F04DAC3-829A-FA1B-E9D0-1E9505713C5C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x92c5d000 - 0x92c5fff7  com.apple.securityhi 4.0 (36638) <38D36D4D-C798-6ACE-5FA8-5C001993AD6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x92c60000 - 0x92ce0feb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x92ce1000 - 0x92d24ff7  com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x92d2c000 - 0x92d3eff7  com.apple.MultitouchSupport.framework 207.11 (207.11) <6FF4F2D6-B8CD-AE13-56CB-17437EE5B741> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x92d4a000 - 0x92d87ff7  com.apple.SystemConfiguration 1.10.8 (1.10.2) <50E4D49B-4F61-446F-1C21-1B2BA814713D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x93082000 - 0x930c5ff7  libGLU.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x9318e000 - 0x934f9ff7  com.apple.QuartzCore 1.6.3 (227.37) /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x934fa000 - 0x935dafe7  com.apple.vImage 4.1 (4.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x935ee000 - 0x93912fef  com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x93913000 - 0x939ccfe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
0x939cd000 - 0x939d1ff7  IOSurface ??? (???) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x9404e000 - 0x94090ff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <3F0ED200-741B-4E27-B89F-634B131F5E9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x94091000 - 0x9409fff7  com.apple.opengl 1.6.13 (1.6.13) <025A905D-C1A3-B24A-1585-37C328D77148> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x940a0000 - 0x940a1ff7  com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <838E1760-F7D9-3239-B3A8-20E25EFD1379> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x940a2000 - 0x940a7ff7  com.apple.OpenDirectory 10.6 (10.6) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x940a8000 - 0x940bdfff  com.apple.ImageCapture 6.1 (6.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x940be000 - 0x940c1fe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x940c7000 - 0x94249fe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) /usr/lib/libicucore.A.dylib
0x9424a000 - 0x94a39557  com.apple.CoreGraphics 1.545.0 (???) <1D9DC7A5-228B-42CB-7018-66F42C3A9BB3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x94a3a000 - 0x94a3cff7  libRadiance.dylib ??? (???) <5920EB69-8D7F-5EFD-70AD-590FCB5C9E6C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x94a3d000 - 0x94a81fe7  com.apple.Metadata 10.6.3 (507.15) <460BEF23-B89F-6F4C-4940-45556C0671B5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x94a82000 - 0x94b1dfe7  com.apple.ApplicationServices.ATS 275.19 (???) <9FA31967-CF14-B033-EB8D-570561D12A13> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x94d82000 - 0x94f29ff7  libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
0x94f2a000 - 0x95224fef  com.apple.QuickTime 7.6.6 (1787) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x95268000 - 0x95273ff7  libGL.dylib ??? (???) <3E34468F-E9A7-8EFB-FF66-5204BD5B4E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x95275000 - 0x95331fff  com.apple.ColorSync 4.6.6 (4.6.6) <7CD8B191-039A-02C3-EA5E-4194EC59995B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x95332000 - 0x9539cfe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x9539d000 - 0x95858ff7  com.apple.VideoToolbox 0.484.60 (484.60) /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x95859000 - 0x9589dff3  com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x9589e000 - 0x9590dff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <2FC2178F-FEF9-6E3F-3289-A6307B1A154C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9590e000 - 0x95a1aff7  libGLProgrammability.dylib ??? (???) <04D7E5C3-B0C3-054B-DF49-3B333DCDEE22> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x95a1b000 - 0x95a1bff7  liblangid.dylib ??? (???) /usr/lib/liblangid.dylib
0x95a1c000 - 0x95a4dff7  libGLImage.dylib ??? (???) <0EE86397-A867-0BBA-E5B1-B800E43FC5CF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x95a4e000 - 0x95cbffef  com.apple.Foundation 6.6.8 (751.63) <69B3441C-B196-F2AD-07F8-D8DD24E4CD8C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x95ced000 - 0x95d34ffb  com.apple.CoreMediaIOServices 140.0 (1496) /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
0x95d35000 - 0x95dddffb  com.apple.QD 3.36 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x95dde000 - 0x95de1ffb  com.apple.help 1.3.2 (41.1) <8AC20B01-4A3B-94BA-D8AF-E39034B97D8C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x95de2000 - 0x95decffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x95ded000 - 0x95dfeff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <97511CC7-FE23-5AC3-2EE2-B5479FAEB316> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x95f82000 - 0x963d3fef  com.apple.RawCamera.bundle 3.7.1 (570) /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x963fb000 - 0x96423ff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <315D97C2-4E1F-A95F-A759-4A3FA5639E75> /usr/lib/libxslt.1.dylib
0x96425000 - 0x96431ff7  libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
0x96432000 - 0x96436ff7  libGIF.dylib ??? (???) <2123645B-AC89-C4E2-8757-85834CAE3DD2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x964a6000 - 0x964a6ff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x964cd000 - 0x964ecff7  com.apple.CoreVideo 1.6.2 (45.6) /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x964ed000 - 0x9650ffef  com.apple.DirectoryService.Framework 3.6 (621.11) /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x96569000 - 0x9657dffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x9657e000 - 0x9662bfe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
0x9662c000 - 0x96632ff7  libCGXCoreImage.A.dylib 545.0.0 (compatibility 64.0.0) <6EE825E7-CBA5-2AD2-0336-244D45A1A834> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x96633000 - 0x9664bff7  com.apple.CFOpenDirectory 10.6 (10.6) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x9664c000 - 0x96655ff7  com.apple.DiskArbitration 2.3 (2.3) /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x96656000 - 0x9665dff3  com.apple.print.framework.Print 6.1 (237.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9665e000 - 0x966f0fe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x966f1000 - 0x96711fe7  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <751955F3-21FB-A03A-4E92-1F3D4EFB8C5B> /usr/lib/libresolv.9.dylib
0x96712000 - 0x96722ff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) /usr/lib/libsasl2.2.dylib
0x967f5000 - 0x967fbfe7  com.apple.CommerceCore 1.0 (9.1) <521D067B-3BDA-D04E-E1FA-CFA526C87EB5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x96835000 - 0x968e1fe7  com.apple.CFNetwork 454.12.4 (454.12.4) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x968e2000 - 0x9697afe7  edu.mit.Kerberos 6.5.11 (6.5.11) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x969c1000 - 0x969ffff7  com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x96ab7000 - 0x96dd7ff3  com.apple.CoreServices.CarbonCore 861.39 (861.39) <5C59805C-AF39-9010-B8B5-D673C9C38538> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x96dd8000 - 0x96de6fe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <3CE8AA79-F077-F1B0-A039-9103A4A02E92> /usr/lib/libz.1.dylib
0x96f69000 - 0x96fc6ff7  com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x9710b000 - 0x9712fff7  libJPEG.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x97130000 - 0x9713dff7  com.apple.NetFS 3.2.2 (3.2.2) /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x9717a000 - 0x9719bfe7  com.apple.opencl 12.3.6 (12.3.6) /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x97276000 - 0x97313fe3  com.apple.LaunchServices 362.3 (362.3) <15B47388-16C8-97DA-EEBB-1709E136169E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x97314000 - 0x97314ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x9733d000 - 0x9743efe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) /usr/lib/libxml2.2.dylib
0x9743f000 - 0x97601feb  com.apple.ImageIO.framework 3.0.4 (3.0.4) <027F55DF-7E4E-2310-1536-3F470CB8847B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x97679000 - 0x97683fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x97735000 - 0x97735ff7  com.apple.Carbon 150 (152) <9252D5F2-462D-2C15-80F3-109644D6F704> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x97865000 - 0x97865ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <1DEC639C-173D-F808-DE0D-4070CC6F5BC7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x97866000 - 0x9788cffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x978a3000 - 0x978e9ff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
0x978ea000 - 0x978eaff7  com.apple.Cocoa 6.6 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x97965000 - 0x97a8bfe7  com.apple.WebKit 6534.51 (6534.51.22) <8E713C26-E90D-0E4B-5FE1-7AFFA8DF2935> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x97aae000 - 0x97aaeff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x97aaf000 - 0x97ae2ff7  com.apple.AE 496.5 (496.5) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x97b47000 - 0x97b47ff7  com.apple.vecLib 3.6 (vecLib 3.6) <7362077A-890F-3AEF-A8AB-22247B10E106> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x97b48000 - 0x97bf6ff3  com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x97bf7000 - 0x97c58fe7  com.apple.CoreText 151.10 (???) <5C2DEFBE-D54B-4DC7-D456-9ED02880BE98> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x97cb4000 - 0x98a18fe7  com.apple.WebCore 6534.51 (6534.51.22) <1E9475BF-87F2-A81F-E096-BBB126BCDF30> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x98a53000 - 0x98a54ff7  com.apple.TrustEvaluationAgent 1.1 (1) <6C04C4C5-667E-2EBE-EB96-5B67BD4B2185> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x98a55000 - 0x98aa5ff7  com.apple.framework.familycontrols 2.0.2 (2020) /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x98aa6000 - 0x98ae7ff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <80998F66-0AD7-AD12-B9AF-3E8D2CE6DE05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x98ae8000 - 0x98bc2fff  com.apple.DesktopServices 1.5.11 (1.5.11) <800F2040-9211-81A7-B438-7712BF51DEE3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x98bc3000 - 0x98d3efe7  com.apple.CoreFoundation 6.6.6 (550.44) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x98ea2000 - 0x99785ff7  com.apple.AppKit 6.6.8 (1038.36) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x99786000 - 0x99800fff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <156A532C-0B60-55B0-EE27-D02B82AA6217> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x99894000 - 0x99af9feb  com.apple.security 6.1.2 (55002) <7F00A51B-F22A-0EBC-A321-923472D686BD> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x99afa000 - 0x99b35feb  libFontRegistry.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x9aa8c000 - 0x9ab57fef  com.apple.CoreServices.OSServices 359.2 (359.2) <7C16D9C8-6F41-5754-17F7-2659D9DD9579> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0xba900000 - 0xba916ff7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
Model: iMac9,1, BootROM IM91.008D.B08, 2 processors, Intel Core 2 Duo, 2.66 GHz, 2 GB, SMC 1.44f0
Graphics: NVIDIA GeForce 9400, NVIDIA GeForce 9400, PCI, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.10.131.42.4)
Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: WDC WD3200AAJS-40H3A0, 298.09 GB
Serial ATA Device: OPTIARC DVD RW AD-5670S
USB Device: SEMC HSUSB Device, 0x0fce  (Sony Ericsson Mobile Communications AB), 0xe14f, 0x24100000 / 3
USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8502, 0x24400000 / 2
USB Device: DCP-145C, 0x04f9  (Brother International Corporation), 0x0206, 0x06400000 / 4
USB Device: USB Receiver, 0x046d  (Logitech Inc.), 0xc52b, 0x06200000 / 3
USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x06100000 / 2
USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8215, 0x06110000 / 7
USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0x04500000 / 3
USB Device: USB Receiver, 0x046d  (Logitech Inc.), 0xc52f, 0x04300000 / 2
Kindly advice!
Michelle
NilsAndreasson
Hi all,
The 1.2 release is out and it should hopefully solve all connectivity issues - meaning you should be able to connect any supported phone in either Media Transfer or Mass Storage mode and have it properly recognized by Bridge. Let me know otherwise!
@michjee and others: This is a known bug that we unfortunately found out about after the 1.2 version was sent for release. It appears when trying to transfer files in mp3 format which contains malformed metadata (song title, album name etc). Possibly it may also be related with data that uses the cyrillic alphabet. As a workaround for now, try experimenting with selecting fewer or different song to see which ones causes problems. Often it may be just one or a few songs that don't work. This will be fixed in the next release, sorry for the trouble.
@Lairyliam: Could you tell me if your problem has been resolved after the 1.2 update? We added some safeguards to protect from what we saw in your log, but since we couldn't reproduce it, it's hard to tell if we succeeed.
Best regards
/Nils
I just installed Sony-Ericsson-Bridge-for-Mac on a macbook air for the first time (running macos 10.7.3).
When I connect to my xperia-mini I get the following stack trace. It happens after about 5 seconds after the program regognizes my android device. That means I cannot conneect without crashes 😞
Michael
Process:         Sony Ericsson Bridge for Mac [375]
Version:         1.2 (3035)
Parent Process:  launchd [239]
Date/Time:       2012-02-14 00:37:04.120 +0100
OS Version:      Mac OS X 10.7.3 (11D50b)
Report Version:  9
Interval Since Last Report:          1464 sec
Crashes Since Last Report:           18
Per-App Interval Since Last Report:  352 sec
Anonymous UUID:                      458ECFD7-4304-43CD-A8D9-85763C2C09A6
Crashed Thread:  5  Dispatch queue: com.apple.root.default-priority
objc[375]: garbage collection is OFF
     0   CoreFoundation                      0x9c7a1b67 __raiseError + 231
     1   libobjc.A.dylib                     0x922fa149 objc_exception_throw + 155
     2   CoreFoundation                      0x9c709369 +[NSException raise:format:arguments:] + 137
     3   CoreFoundation                      0x9c7092d9 +[NSException raise:format:] + 57
     4   Foundation                          0x93a3e75e -[NSPlaceholderString initWithString:] + 98
     5   Foundation                          0x93a3e6e2 +[NSString stringWithString:] + 67
     10  Sony Ericsson Bridge for Mac        0x000146eb -[DRContentOpSynchronize main] + 1357
     11  Foundation                          0x93a651ff -[__NSOperationInternal start] + 797
     12  Foundation                          0x93a64edb -[NSOperation start] + 67
     13  Foundation                          0x93a7902e ____NSOQSchedule_block_invoke_2 + 135
     14  libdispatch.dylib                   0x950d5e11 _dispatch_call_block_and_release + 15
     15  libdispatch.dylib                   0x950d6e70 _dispatch_worker_thread2 + 231
     16  libsystem_c.dylib                   0x9b5ccb24 _pthread_wqthread + 346
     17  libsystem_c.dylib                   0x9b5ce6fe start_wqthread + 30
