Problem with Sony Ericsson Bridge for Mac
I installed the Sony Ericsson Bridge for Mac application, but impossible to use it.
It says something like "The application closed in an unexpected way" (I use a French language mac). Sometimes I can launch it for a few seconds though, but then still get the error message.
Details or error:
Process:         Sony Ericsson Bridge for Mac [415]
Path:            /Applications/Sony Ericsson Bridge for Mac.app/Contents/MacOS/Sony Ericsson Bridge for Mac
Identifier:      com.sonyericsson.Sony-Ericsson-Bridge-for-Mac
Version:         1.0.1 (3015)
Code Type:       X86 (Native)
Parent Process:  launchd [221]
Date/Time:       2011-12-04 11:47:06.470 +0800
OS Version:      Mac OS X 10.6.8 (10K549)
Report Version:  6
Interval Since Last Report:          2401390 sec
Crashes Since Last Report:           32
Per-App Interval Since Last Report:  104 sec
Per-App Crashes Since Last Report:   20
Anonymous UUID:                      FCDEC200-1C8C-4D5D-8972-EC766B9EB66C
Exception Type:  EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread:  4  Dispatch queue: com.apple.root.default-priority
45 REPLIES 45
NilsAndreasson
Yes unfortunately this is a known problem. See above post under "@michjee and others:" for an explanation. I have no real explanation as to why you get the error right away. Perhaps if you already have music files on your phone with the kind of problems described above. A fix is coming.
Hi Nils
The 1.2 version runs OK on my PowerMac with Snow Leopard but I have problems syncing with iTunes. With multiple songs selected, the sync will stall part way through. I tried copying individual songs and some go OK and with others the progress bar appears to complete but the software still says 'sync in progress'. If I cancel the sync, sometime the song is actually available on the phone and sometime it isn't.
Is there any work-around?
Thanks
I am running Bridge v.2.2 and have been experiencing problems with media transfer from my Mac to Xperia Ray since I bought it about 4 weeks ago, I had no problem updating the android to the latest version btw, and on that department Bridge worked like a charm, however when I tried to put some mp3's on it, strange thing happened, it does transfer files on the phone but they are not being recognized though when I do check my settings/storage/audio I can see the amount of MB's being in the music folder, next to that I can see when opening the folder witout the Bridge that the files are there and are playable through my mac from the SD Card, but the phone simply refuses to see them ... so, tried to contact the support etc. got really bad response from which I had absolutely nothing as what I got had to do only with Windows systems and not Mac what I have explicitly stated, but not to go astray from the matter at hand now. I found out, that if I start up my phone, start up my mac, connect Xperia Ray, start Bridge and sync one song with iTunes through it, it does see all of the audio content, however this only lasts for one transfer of the files (playlist sync doesn't work at all btw), if I try to do more, the phone reverts to not seeing files again, as well, if I restart the phone same thing happens... I am sorry but since I have not experienced crash I can not give you a crash log, but hope that this can indicate you the bug in some way and that you will be able to either give me some idea how to solve it or that it will work out for you that way so that you will be able to improve on the software.
I am running,
2.2Ghz IntelCore 2 Duo
Mac OSX 10.6.8
Sony Bridge 2.2
Android 4.0.3
p.s.
Also would like to add that I did try to copy files directly to the SD Card without Bridge in the MMS Mode and it did not work.
Bridge for MAC ver. 2.2 crashes too:
Process:         Sony Ericsson Bridge for Mac [1518]
Version:         2.2 (3071)
Parent Process:  launchd [124]
Date/Time:       2012-05-29 09:27:19.904 +0200
OS Version:      Mac OS X 10.7.4 (11E53)
Report Version:  9
Interval Since Last Report:          492165 sec
Crashes Since Last Report:           6
Per-App Interval Since Last Report:  1297 sec
Per-App Crashes Since Last Report:   6
Anonymous UUID:                      AD79CB4A-DA81-4332-9A47-453555513846
Crashed Thread:  2  Dispatch queue: com.apple.root.default-priority
Application Specific Information:
objc[1518]: garbage collection is OFF
*** Terminating app due to uncaught exception 'NSMallocException', reason: '*** attempt to create a temporary id buffer of length (23782) failed'
*** Call stack at first throw:
          0   CoreFoundation                      0x91dc6a67 __raiseError + 231
          1   libobjc.A.dylib                     0x976ff149 objc_exception_throw + 155
          2   CoreFoundation                      0x91cd4c71 -[NSArray initWithArray:range:copyItems:] + 945
          3   CoreFoundation                      0x91d02fe5 +[NSArray arrayWithArray:] + 101
          4   DeviceConnectivity                  0x00406002 -[DRFilesystem fileForSourcePath:inParent:] + 136
          5   Sony Ericsson Bridge for Mac        0x0000aa33 -[DRContentOpIndexFolder main] + 644
          6   Foundation                          0x927051cb -[__NSOperationInternal start] + 797
          7   Foundation                          0x92704ea7 -[NSOperation start] + 67
          8   Foundation                          0x92718ffa ____NSOQSchedule_block_invoke_2 + 135
          9   libdispatch.dylib                   0x9c40bfc9 _dispatch_call_block_and_release + 15
          10  libdispatch.dylib                   0x9c40d028 _dispatch_worker_thread2 + 231
          11  libsystem_c.dylib                   0x962efb24 _pthread_wqthread + 346
          12  libsystem_c.dylib                   0x962f16fe start_wqthread + 30
Thread 0:: Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib                  0x97ed4c22 mach_msg_trap + 10
1   libsystem_kernel.dylib                  0x97ed41f6 mach_msg + 70
2   com.apple.CoreFoundation                0x91cb39da __CFRunLoopServiceMachPort + 170
3   com.apple.CoreFoundation                0x91cbcb04 __CFRunLoopRun + 1428
4   com.apple.CoreFoundation                0x91cbc1dc CFRunLoopRunSpecific + 332
5   com.apple.CoreFoundation                0x91cbc088 CFRunLoopRunInMode + 120
6   com.apple.HIToolbox                     0x98181723 RunCurrentEventLoopInMode + 318
7   com.apple.HIToolbox                     0x98188a8b ReceiveNextEventCommon + 381
8   com.apple.HIToolbox                     0x981888fa BlockUntilNextEventMatchingListInMode + 88
9   com.apple.AppKit                        0x902900d8 _DPSNextEvent + 678
10  com.apple.AppKit                        0x9028f942 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 113
11  com.apple.AppKit                        0x9028bcb1 -[NSApplication run] + 911
12  com.apple.AppKit                        0x9051cbd9 NSApplicationMain + 1054
13  com.sonyericsson.Sony-Ericsson-Bridge-for-Mac          0x00002709 start + 53
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0   libsystem_kernel.dylib                  0x97ed790a kevent + 10
1   libdispatch.dylib                       0x9c40de10 _dispatch_mgr_invoke + 969
2   libdispatch.dylib                       0x9c40c85f _dispatch_mgr_thread + 53
Thread 2 Crashed:: Dispatch queue: com.apple.root.default-priority
0   com.apple.CoreFoundation                0x91dc6957 ___TERMINATING_DUE_TO_UNCAUGHT_EXCEPTION___ + 7
2   com.apple.CoreFoundation                0x91cd4c71 -[NSArray initWithArray:range:copyItems:] + 945
3   com.apple.CoreFoundation                0x91d02fe5 +[NSArray arrayWithArray:] + 101
4   com.divinerobot.DeviceConnectivity          0x00406002 -[DRFilesystem fileForSourcePath:inParent:] + 136
5   com.sonyericsson.Sony-Ericsson-Bridge-for-Mac          0x0000aa33 -[DRContentOpIndexFolder main] + 644
6   com.apple.Foundation                    0x927051cb -[__NSOperationInternal start] + 797
7   com.apple.Foundation                    0x92704ea7 -[NSOperation start] + 67
8   com.apple.Foundation                    0x92718ffa ____NSOQSchedule_block_invoke_2 + 135
Thread 3:: com.apple.NSURLConnectionLoader
6   com.apple.Foundation                    0x927240c4 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 378
7   com.apple.Foundation                    0x92717e25 -[NSThread main] + 45
8   com.apple.Foundation                    0x92717dd5 __NSThread__main__ + 1582
9   libsystem_c.dylib                       0x962eded9 _pthread_start + 335
10  libsystem_c.dylib                       0x962f16de thread_start + 34
Thread 4:: com.apple.CFSocket.private
0   libsystem_kernel.dylib                  0x97ed6b42 __select + 10
1   com.apple.CoreFoundation                0x91d0ae15 __CFSocketManager + 1557
2   libsystem_c.dylib                       0x962eded9 _pthread_start + 335
3   libsystem_c.dylib                       0x962f16de thread_start + 34
Thread 2 crashed with X86 Thread State (32-bit):
  eax: 0x00000001  ebx: 0x006b3350  ecx: 0x00000001  edx: 0x00000000
  edi: 0x0120e420  esi: 0x976ff0bf  ebp: 0xb01843b8  esp: 0xb01843b0
   ss: 0x00000023  efl: 0x00000282  eip: 0x91dc6957   cs: 0x0000001b
   ds: 0x00000023   es: 0x00000023   fs: 0x00000023   gs: 0x0000000f
  cr2: 0x04aff000
Logical CPU: 2
Binary Images:
    0x1000 -    0x7dffb +com.sonyericsson.Sony-Ericsson-Bridge-for-Mac (2.2 - 3071) <757B7C14-F48D-3A48-BB4B-CA04E25A7C19> /Applications/Sony Ericsson Bridge for Mac.app/Contents/MacOS/Sony Ericsson Bridge for Mac
   0xf3000 -   0x30bffb +com.sonyericsson.framework.DeviceUpdate (1.0 - 1) <85C5E11A-03C9-3B33-8490-D83B851C285A> /Applications/Sony Ericsson Bridge for Mac.app/Contents/Frameworks/DeviceUpdate.framework/Versions/A/DeviceUpdate
  0x3cb000 -   0x422ffb +com.divinerobot.DeviceConnectivity (1.0 - 1) <38994A99-AC12-3B6A-8FE5-E376751920F1> /Applications/Sony Ericsson Bridge for Mac.app/Contents/Frameworks/DeviceConnectivity.framework/Versions/A/DeviceConnectivity
  0x45e000 -   0x464fff +com.sonyericsson.SonyBridgeGeneric (1.0 - 1) <2CA9DDBA-8E92-3ACF-9721-9714556004DC> /Applications/Sony Ericsson Bridge for Mac.app/Contents/Frameworks/SonyBridgeGeneric.framework/Versions/A/SonyBridgeGeneric
  0x46a000 -   0x47dfff +org.andymatuschak.Sparkle (1.5 Beta 6 - 313) <5DF2B8A3-560D-4500-6B85-4215644DE532> /Applications/Sony Ericsson Bridge for Mac.app/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
  0x48b000 -   0x538ff7  libcrypto.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <7B6DB792-C9E5-3772-8734-8D0052757B8C> /usr/lib/libcrypto.0.9.7.dylib
  0x5f1000 -   0x5f1ff3 +cl_kernels (??? - ???) <6A821EAF-4C66-4416-9D77-7E0C25CB9CC4> cl_kernels
0x4a88000 -  0x4a8dfe2  libcldcpuengine.dylib (1.50.69 - compatibility 1.0.0) <864BA467-5F11-3B41-B261-894067B8209E> /System/Library/Frameworks/OpenCL.framework/Libraries/libcldcpuengine.dylib
0x4a94000 -  0x4a96fff  libCoreFSCache.dylib (??? - ???) <5B141DE1-6FC9-3155-833B-23A447A598AB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x4abe000 -  0x4abeffb +cl_kernels (??? - ???) <64424E47-B42A-4246-9724-893BFD4FCF72> cl_kernels
0x4ac4000 -  0x4ac5ff6 +cl_kernels (??? - ???) <558D068E-5779-4E8F-B84A-7B4F299B25B4> cl_kernels
0x5d49000 -  0x5de8ff7  unorm8_rgba.dylib (1.50.69 - compatibility 1.0.0) <3A06E8EA-0335-348A-BCCB-21C3E94AED31> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_rgba.dylib
0x5dfe000 -  0x5e9fff7  unorm8_bgra.dylib (1.50.69 - compatibility 1.0.0) <7A0427BD-4FB5-3F4E-A7F8-F760AD944283> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_bgra.dylib
0x8fa6000 -  0x8fafffb  com.apple.iokit.IOUSBLib (4.4.5 - 4.4.5) <754D0668-DA34-33DC-8C10-F689E3053761> /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0xa900000 -  0xa985ffa  com.apple.xquery (1.3 - 29) <402F00BB-0CBF-3CD3-A752-361A65C906E7> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
0x8fe71000 - 0x8fea3aa7  dyld (195.6 - ???) <3A866A34-4CDD-35A4-B26E-F145B05F3644> /usr/lib/dyld
0x90012000 - 0x90285ffb  com.apple.CoreImage (7.98 - 1.0.1) /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x90286000 - 0x90d1bff6  com.apple.AppKit (6.7.3 - 1138.47) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x9104c000 - 0x91095ff7  libGLU.dylib (??? - ???) <5EE0B644-FAD6-3E3C-A380-9B0CDA0B6432> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x91096000 - 0x91096ffe  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
0x910ff000 - 0x91186fff  com.apple.print.framework.PrintCore (7.1 - 366.3) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x91187000 - 0x911a9ffe  com.apple.framework.familycontrols (3.0 - 300) <5BCCDDC2-AFAC-3290-AEEF-23B2664CA11F> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x911aa000 - 0x91282ff6  com.apple.QuickLookUIFramework (3.2 - 500.16) <1598FDEB-8F90-3D42-AAA1-CD227F3C16BF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x9130e000 - 0x91528ff7  com.apple.imageKit (2.1.2 - 1.0) <0A14D083-5217-3180-A354-A5FDC754E3FC> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x91529000 - 0x9152afff  liblangid.dylib (??? - ???) /usr/lib/liblangid.dylib
0x91578000 - 0x9157fff8  libCGXCoreImage.A.dylib (600.0.0 - compatibility 64.0.0) <3E1A07C0-AC27-3070-945D-A9C2A71DEADB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x915b4000 - 0x915bffff  libkxld.dylib (??? - ???) /usr/lib/system/libkxld.dylib
0x915ef000 - 0x91606ff8  com.apple.CoreMediaAuthoring (2.0 - 891) <69D569FD-670C-3BD0-94BF-7A8954AA2953> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x91607000 - 0x91612ffc  com.apple.NetAuth (1.0 - 3.0) /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x91613000 - 0x9161eff3  libCSync.A.dylib (600.0.0 - compatibility 64.0.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x9161f000 - 0x91730ff7  libJP2.dylib (??? - ???) <845C74F4-1074-3983-945F-EB669538CAA9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x91731000 - 0x91929ff7  com.apple.CoreData (104.1 - 358.14) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9192a000 - 0x91938ff7  libxar-nossl.dylib (??? - ???) <5BF4DA8E-C319-354A-967E-A0C725DC8BA3> /usr/lib/libxar-nossl.dylib
0x91986000 - 0x91aa4fec  com.apple.vImage (5.1 - 5.1) <7757F253-B281-3612-89D4-F2B04061CBE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91aa6000 - 0x91b08ffb  com.apple.datadetectorscore (3.0 - 179.4) <3A418498-C189-37A1-9B86-F0ECB33AD91C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x91b0e000 - 0x91b11ffd  libCoreVMClient.dylib (??? - ???) <361CCFAF-8565-383F-915F-0B059C793E42> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x91b12000 - 0x91b16ff3  libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib
0x91b17000 - 0x91b18ffd  libCVMSPluginSupport.dylib (??? - ???) <22B85645-AA98-372B-BB55-55DCCF0EC716> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x91b3e000 - 0x91b45ff9  libsystem_dnssd.dylib (??? - ???) /usr/lib/system/libsystem_dnssd.dylib
0x91b46000 - 0x91b87ff9  libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <9FD420FB-7984-3A07-8914-BB19E687D38B> /usr/lib/libcurl.4.dylib
0x91b88000 - 0x91bd7ffb  com.apple.AppleVAFramework (5.0.14 - 5.0.14) <7FF10781-5418-37BB-A6B3-1606DA82CBFF> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x91bf2000 - 0x91bf5ff9  libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <1211BEEB-31C9-3A5D-9E71-10FC4A541D1E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x91bf6000 - 0x91c80ffb  com.apple.SearchKit (1.4.0 - 1.4.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x91c81000 - 0x91e58fe7  com.apple.CoreFoundation (6.7.2 - 635.21) <4D1D2BAF-1332-32DF-A81B-7E79D4F0A6CB> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x91e59000 - 0x91e82ffe  com.apple.opencl (1.50.69 - 1.50.69) <2601993F-F3B3-3737-91AE-4A5795C52CD5> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x91e83000 - 0x91e83fff  libdnsinfo.dylib (395.11.0 - compatibility 1.0.0) <7EFAD88C-AFBC-3D48-BE14-60B8EACC68D7> /usr/lib/system/libdnsinfo.dylib
0x91e84000 - 0x91efcff8  com.apple.CorePDF (3.1 - 3.1) <0074267B-F74A-30FC-8508-A14C821F0771> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x91efd000 - 0x92182fe3  com.apple.QuickTime (7.7.1 - 2330) <060B6A47-FC15-3D38-8EFB-FCF38680510B> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x921ce000 - 0x92242fff  com.apple.CoreSymbolication (2.2 - 73.2) /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x9237b000 - 0x92395fff  com.apple.Kerberos (1.0 - 1) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x92396000 - 0x923a4fff  com.apple.opengl (1.7.7 - 1.7.7) <2D362F15-5EA6-37B6-9BCB-58F2C599ACDA> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x923a5000 - 0x923d3fe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <30189C33-6ADD-3142-83F3-6114B1FC152E> /usr/lib/libSystem.B.dylib
0x923d4000 - 0x92417ffd  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <4BA1F5F1-F0A2-3FEB-BB62-F514DCBB3725> /usr/lib/system/libcommonCrypto.dylib
0x92418000 - 0x92421ff3  com.apple.CommonAuth (2.2 - 2.0) /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x9250e000 - 0x9252bff3  com.apple.openscripting (1.3.3 - ???) <33713C0B-B7D5-37AA-87DB-2727FDCC8007> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x92589000 - 0x925c6ff7  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <1C757924-4E54-3522-A885-99795EA10228> /usr/lib/libcups.2.dylib
0x925c7000 - 0x926b7ff1  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
0x926b8000 - 0x929c2ff3  com.apple.Foundation (6.7.2 - 833.25) <4C52ED74-A1FD-3087-A2E1-035AB3CF9610> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x929c3000 - 0x92db7ffb  com.apple.VideoToolbox (1.0 - 705.78) /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x92db8000 - 0x92dbbfff  com.apple.AppleSystemInfo (1.0 - 1) /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x92e31000 - 0x92e3cffe  libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <4A7FCD28-9C09-3120-980A-BDF6EDFAAC62> /usr/lib/libbz2.1.0.dylib
0x92e3d000 - 0x92e59ff5  com.apple.GenerationalStorage (1.0 - 126.1) /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x92e7f000 - 0x93033ff3  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <6AD14A51-AEA8-3732-B07B-DEA37577E13A> /usr/lib/libicucore.A.dylib
0x93034000 - 0x93051fff  libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <2870320A-28DA-3B44-9D82-D56E0036F6BB> /usr/lib/libresolv.9.dylib
0x93052000 - 0x93a83fff  com.apple.WebCore (7534.56 - 7534.56.5) <568036DA-63F6-33E5-B25D-D66DF1B1C2E7> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x93a84000 - 0x93a88fff  libGIF.dylib (??? - ???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x93a89000 - 0x93a8afff  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) /usr/lib/system/libsystem_blocks.dylib
0x93bd7000 - 0x93bdcffd  libGFXShared.dylib (??? - ???) <1CA9B41B-2C61-38F8-ABAC-1D5511478F5C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x93bdd000 - 0x93cb4ff3  com.apple.avfoundation (2.0 - 180.40) /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x93cc4000 - 0x941a0ff6  libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x941a1000 - 0x941b6ff7  com.apple.ImageCapture (7.0.1 - 7.0.1) <1C8933A9-C7C6-36E9-9D8B-0EF08ACA3315> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x941b7000 - 0x941e6ff7  libsystem_info.dylib (??? - ???) <37640811-445B-3BB7-9934-A7C99848250D> /usr/lib/system/libsystem_info.dylib
0x941e7000 - 0x94210fff  com.apple.shortcut (2.1 - 2.1) /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x9425b000 - 0x94285ff0  libpcre.0.dylib (1.1.0 - compatibility 1.0.0) <5CAA1478-97E0-31EA-8F50-BF09D665DD84> /usr/lib/libpcre.0.dylib
0x94921000 - 0x94929ff3  liblaunch.dylib (392.38.0 - compatibility 1.0.0) /usr/lib/system/liblaunch.dylib
0x9492a000 - 0x9492bff0  libunc.dylib (24.0.0 - compatibility 1.0.0) /usr/lib/system/libunc.dylib
0x9492c000 - 0x9496cff7  com.apple.NavigationServices (3.7 - 193) <16A8BCC8-7343-3A90-88B3-AAA334DF615F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x94bb7000 - 0x94f71ffb  com.apple.SceneKit (125.3 - 125.4) <48806882-FE04-36A5-83A1-A0D2F2FA03F9> /System/Library/PrivateFrameworks/SceneKit.framework/Versions/A/SceneKit
0x94f72000 - 0x94f76ff7  com.apple.OpenDirectory (10.7 - 146) <4986A382-8FEF-3392-8CE9-CF6A5EE4E365> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x94f77000 - 0x94f7bffa  libcache.dylib (47.0.0 - compatibility 1.0.0) <98A82BC5-0DD9-3212-9CAE-35A77278EEB6> /usr/lib/system/libcache.dylib
0x94f7c000 - 0x94ff9ffe  com.apple.PDFKit (2.6.3 - 2.6.3) <780A5EE1-48CB-3B80-BBDF-1081512BA0DC> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x94ffa000 - 0x95008fff  libz.1.dylib (1.2.5 - compatibility 1.0.0) /usr/lib/libz.1.dylib
0x95009000 - 0x95012ffc  com.apple.DisplayServicesFW (2.5.4 - 323.3) <820C4B45-814A-3101-A1FA-044CA6D2FBC8> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x95013000 - 0x9504afef  com.apple.DebugSymbols (2.1 - 87) /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x95090000 - 0x950a0fff  libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) /usr/lib/libsasl2.2.dylib
0x950a1000 - 0x950a4ff7  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
0x950a5000 - 0x950acffd  com.apple.NetFS (4.0 - 4.0) /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x950ad000 - 0x9517dffb  com.apple.ImageIO.framework (3.1.2 - 3.1.2) <94798A2B-4C7A-30EA-9920-283451BDB9FA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x9517e000 - 0x9517eff2  com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x9517f000 - 0x951a7ff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0) /usr/lib/libxslt.1.dylib
0x951a8000 - 0x951acffd  IOSurface (??? - ???) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x951ad000 - 0x9530ffff  com.apple.QTKit (7.7.1 - 2330) /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x95310000 - 0x95317ff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib
0x95318000 - 0x95368ff8  libTIFF.dylib (??? - ???) <4DC2025D-15E7-35CA-B7C5-9F73B26C8B53> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x9568c000 - 0x959d2fff  com.apple.MediaToolbox (1.0 - 705.78) /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x959d3000 - 0x959e3ff7  libCRFSuite.dylib (??? - ???) /usr/lib/libCRFSuite.dylib
0x959e4000 - 0x95e59ff7  FaceCoreLight (1.4.7 - compatibility 1.0.0) <3E2BF587-5168-3FC5-9D8D-183A9C7C1DED> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
0x95e5a000 - 0x95ec9fff  com.apple.Heimdal (2.2 - 2.0) <2E1B8779-36D4-3C62-A67E-0034D77D7707> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x95eca000 - 0x95ecbff7  libsystem_sandbox.dylib (??? - ???) /usr/lib/system/libsystem_sandbox.dylib
0x95ecc000 - 0x95ecdfff  libDiagnosticMessagesClient.dylib (??? - ???) /usr/lib/libDiagnosticMessagesClient.dylib
0x95ece000 - 0x95edbfff  libGL.dylib (??? - ???) <30E6DED6-0213-3A3B-B2B3-310E33301CCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x95edc000 - 0x95f02ffb  com.apple.quartzfilters (1.7.0 - 1.7.0) <9C8F1F3D-D570-3F5C-9B31-5B5B82161CDE> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x95fc9000 - 0x95fc9fff  com.apple.quartzframework (1.5 - 1.5) /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x95fca000 - 0x95fefff9  libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x95ff0000 - 0x9601bfff  com.apple.GSS (2.2 - 2.0) <2C468B23-FA87-30B5-B9A6-8C5D1373AA30> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x9601c000 - 0x96030ff7  com.apple.CFOpenDirectory (10.7 - 144) <665CDF77-F0C9-3AFF-8CF8-64257268B7DD> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x96031000 - 0x96053ff8  com.apple.PerformanceAnalysis (1.11 - 11) <453463FF-7C42-3526-8C96-A9971EE07154> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x96060000 - 0x96063ffc  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
0x96064000 - 0x9609aff7  com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x9609b000 - 0x960cfff8  libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <567E922C-E64F-321B-9A47-6B18BF481625> /usr/lib/libssl.0.9.8.dylib
0x961ad000 - 0x96211fff  com.apple.framework.IOKit (2.0 - ???) <88D60E59-430D-35B8-B1E9-F5138301AEF9> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x96212000 - 0x9621aff5  libcopyfile.dylib (85.1.0 - compatibility 1.0.0) /usr/lib/system/libcopyfile.dylib
0x9623f000 - 0x96243fff  com.apple.CommonPanels (1.2.5 - 94) <3A988595-DE53-34ED-9367-C9A737E2AF38> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x96291000 - 0x9635cfff  libsystem_c.dylib (763.13.0 - compatibility 1.0.0) <52421B00-79C8-3727-94DE-62F6820B9C31> /usr/lib/system/libsystem_c.dylib
0x9635d000 - 0x96420fff  com.apple.CoreServices.OSServices (478.46 - 478.46) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x96421000 - 0x9642efff  com.apple.HelpData (2.1.2 - 72.2) <330C6B7F-2512-37B7-B2FF-24E1804E9426> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x9642f000 - 0x96d5959b  com.apple.CoreGraphics (1.600.0 - ???) <62026E0C-E30F-3FF0-B0F6-6A2D270B20BF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x96d5e000 - 0x96d5efff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x96d5f000 - 0x96db1ffb  com.apple.CoreMediaIO (212.0 - 3199.1.1) /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x96db2000 - 0x96dd2ff7  com.apple.RemoteViewServices (1.4 - 44.1) <1F831750-1E77-3013-B1A6-0DF528623790> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x96dfa000 - 0x96e5cff3  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
0x96e63000 - 0x96edeffb  com.apple.ApplicationServices.ATS (317.11.0 - ???) <42238C8B-C93F-3369-A500-EC0F10EB2C80> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x96edf000 - 0x96f30ff9  com.apple.QuickLookFramework (3.2 - 500.16) <725FAE01-1597-38C7-841D-D9D83358921E> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x96fdd000 - 0x97025ff7  com.apple.SystemConfiguration (1.11.3 - 1.11) <68B92FEA-F754-3E7E-B5E6-D512E26144E7> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x97026000 - 0x97026fff  com.apple.audio.units.AudioUnit (1.7.2 - 1.7.2) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x97027000 - 0x97065fff  libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <19174EC0-DE0F-38EA-B5F3-7580E84677DD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x97066000 - 0x97313ff3  com.apple.JavaScriptCore (7534.56 - 7534.56.6) <94C4DC32-FE6B-3D5C-93B5-75753F38A0C0> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x973fc000 - 0x97404ff3  libunwind.dylib (30.0.0 - compatibility 1.0.0) /usr/lib/system/libunwind.dylib
0x9740d000 - 0x9745fff7  libFontRegistry.dylib (??? - ???) <96E9602C-DFD3-3021-8090-60228CC80D26> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x97460000 - 0x97460fff  com.apple.Carbon (153 - 153) <6FF98F0F-2CDE-3888-A304-4ED447D24CE3> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x97461000 - 0x9768affb  com.apple.QuartzComposer (5.0 - 236.7) <1504F5A4-FF1A-365E-9E01-30410C561C2C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x9768b000 - 0x976e4fff  com.apple.HIServices (1.21 - ???) <5F4D3797-32E2-3709-85F4-4B56515A17D7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x976e5000 - 0x976ebffd  com.apple.CommerceCore (1.0 - 17) <71641C17-1CA7-3AC9-974E-AAC9EB641035> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x976ec000 - 0x977c2aab  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <2E272DCA-38A0-3530-BBF4-47AE678D20D4> /usr/lib/libobjc.A.dylib
0x977c9000 - 0x97a8cfff  com.apple.security (7.0 - 55148.1) <77754898-4FCD-3CA3-9339-F1058C852806> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x97a8d000 - 0x97e8fff6  libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x97e90000 - 0x97e91ff7  libquarantine.dylib (36.6.0 - compatibility 1.0.0) <600909D9-BD75-386E-8D3E-7CBD29079DF3> /usr/lib/system/libquarantine.dylib
0x97ebe000 - 0x97edcff7  libsystem_kernel.dylib (1699.26.8 - compatibility 1.0.0) <3705DE40-E00F-3E37-ADB0-D4AE5F9950F5> /usr/lib/system/libsystem_kernel.dylib
0x97fa3000 - 0x9803ffef  com.apple.ink.framework (1.4 - 110) <1A3E2916-60C1-3AC1-86BF-202F6567B228> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x98040000 - 0x98138ff7  libFontParser.dylib (??? - ???) <1A0DA421-62B2-3AA7-9F62-0E01C1887D09> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x9817e000 - 0x9817eff0  com.apple.ApplicationServices (41 - 41) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9817f000 - 0x984c5ff3  com.apple.HIToolbox (1.9 - ???) <409E6397-0DCB-3431-9CCC-368317C62545> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x984cf000 - 0x98566ff3  com.apple.securityfoundation (5.0 - 55116) /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x98567000 - 0x98666ffb  com.apple.DiskImagesFramework (10.7.4 - 331.6) <8CC0C204-1069-3CC3-9CE1-3CDF92757E5B> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x98667000 - 0x98678fff  libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
0x98679000 - 0x986d6ffb  com.apple.htmlrendering (76 - 1.1.4) <743C2943-40BC-36FB-A45C-3421A394F081> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x986d7000 - 0x98713ffa  libGLImage.dylib (??? - ???) <504E7865-571E-38B4-A84A-D7B513AC84F5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x98714000 - 0x98775ffb  com.apple.audio.CoreAudio (4.0.2 - 4.0.2) /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x98776000 - 0x98781ffb  com.apple.speech.recognition.framework (4.0.21 - 4.0.21) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x98782000 - 0x98797fff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x988d5000 - 0x98bd7fff  com.apple.CoreServices.CarbonCore (960.24 - 960.24) <9692D838-85A5-32C1-B7FB-7C141FFC2557> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x98bd8000 - 0x98ceffe9  com.apple.WebKit (7534.56 - 7534.56.5) <1EFE77EE-97B8-3D3C-B2ED-0FA4328E418B> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x98cf0000 - 0x98d1aff1  com.apple.CoreServicesInternal (113.17 - 113.17) <41979516-2F26-3707-A6CA-7A95A1B0D963> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x98d85000 - 0x98de3fff  com.apple.coreui (1.2.2 - 165.10) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x98de4000 - 0x98e88fff  com.apple.QD (3.40 - ???) <3881BEC6-0908-3073-BA44-346356E1CDF9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x99bda000 - 0x99c50fff  com.apple.Metadata (10.7.0 - 627.32) <650EE880-1488-3DC6-963B-F3D6E043FFDC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9a5f2000 - 0x9a608ffe  libxpc.dylib (77.19.0 - compatibility 1.0.0) <0585AA94-F4FD-32C1-B586-22E7184B781A> /usr/lib/system/libxpc.dylib
0x9a609000 - 0x9a60eff7  libmacho.dylib (800.0.0 - compatibility 1.0.0) <56A34E97-518E-307E-8218-C5D43A33EE34> /usr/lib/system/libmacho.dylib
0x9a60f000 - 0x9a642fef  libtidy.A.dylib (??? - ???) /usr/lib/libtidy.A.dylib
0x9a643000 - 0x9a666fff  com.apple.CoreVideo (1.7 - 70.3) <4234C11C-E8E9-309A-9465-27D6D7458895> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x9a667000 - 0x9a66affb  com.apple.help (1.3.2 - 42) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x9a66b000 - 0x9a6f8fe7  libvMisc.dylib (325.4.0 - compatibility 1.0.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9a6f9000 - 0x9a6fbff7  libdyld.dylib (195.5.0 - compatibility 1.0.0) <637660EA-8D12-3B79-B644-041FEADC9C33> /usr/lib/system/libdyld.dylib
0x9a7c7000 - 0x9a8d6fff  com.apple.DesktopServices (1.6.3 - 1.6.3) <18CAAA9E-7065-3FF7-ACFE-CDB60E5426A2> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x9a9ec000 - 0x9aef8fff  com.apple.RawCamera.bundle (3.13.0 - 627) <3859CCFE-E5FB-3EA6-7D4D-D32801FC31E4> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x9af66000 - 0x9af69ff7  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
0x9af6a000 - 0x9af7dff8  com.apple.MultitouchSupport.framework (231.4 - 231.4) <083F7787-4C3B-31DA-B5BB-1993D9A9723D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x9af7e000 - 0x9af86fff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x9afe1000 - 0x9b0c4ff7  libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) /usr/lib/libcrypto.0.9.8.dylib
0x9b1d2000 - 0x9b1dbfff  libc++abi.dylib (14.0.0 - compatibility 1.0.0) /usr/lib/libc++abi.dylib
0x9b216000 - 0x9b216fff  com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x9b217000 - 0x9b2f8ff7  com.apple.DiscRecording (6.0.4 - 6040.4.1) <08BADDAD-FA79-3872-9387-EEE2A9FAA2F0> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x9b309000 - 0x9b364ff3  com.apple.Symbolication (1.3 - 91) <4D12D2EC-5010-3958-A205-9A67E972C76A> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x9b365000 - 0x9b375fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9b376000 - 0x9b3a4ff7  com.apple.DictionaryServices (1.2.1 - 158.2) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x9b3a5000 - 0x9b4d1ff9  com.apple.CFNetwork (520.4.3 - 520.4.3) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x9b4d2000 - 0x9b516fff  com.apple.MediaKit (12 - 602) <6E429DD7-8829-37DE-94AF-940FB70F2FB9> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x9b517000 - 0x9b57cff7  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x9b57d000 - 0x9b57eff4  libremovefile.dylib (21.1.0 - compatibility 1.0.0) <6DE3FDC7-0BE0-3791-B6F5-C15422A8AFB8> /usr/lib/system/libremovefile.dylib
0x9b57f000 - 0x9b581ffb  libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x9b718000 - 0x9b76aff3  com.apple.ImageCaptureCore (3.0.3 - 3.0.3) <9C6A4134-0D1D-323F-BD07-1D88D258A7B4> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x9b76b000 - 0x9b7adff7  com.apple.CoreMedia (1.0 - 705.78) /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x9b7ae000 - 0x9b7ffff9  com.apple.ScalableUserInterface (1.0 - 1) /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x9b800000 - 0x9b8c0ffb  com.apple.ColorSync (4.7.4 - 4.7.4) <0A68AF35-15DF-3A0A-9B17-70CE2A106A6C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x9b8c1000 - 0x9bf3cfe5  com.apple.CoreAUC (6.16.11 - 6.16.11) /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x9bf45000 - 0x9bf47ff9  com.apple.securityhi (4.0 - 1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x9bf4a000 - 0x9bf4afff  com.apple.Cocoa (6.6 - ???) <650273EF-1ABC-334E-B745-B75AF028F9F4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x9c000000 - 0x9c006ffb  com.apple.print.framework.Print (7.4 - 247.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9c007000 - 0x9c159fff  com.apple.audio.toolbox.AudioToolbox (1.7.2 - 1.7.2) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9c15a000 - 0x9c15bfff  com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x9c15c000 - 0x9c244fff  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <1841196F-68B5-309F-8ED1-6714B1DFEC83> /usr/lib/libxml2.2.dylib
0x9c245000 - 0x9c24fff2  com.apple.audio.SoundManager (3.9.4.1 - 3.9.4.1) <2A089CE8-9760-3F0F-B77D-29A78940EA17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x9c294000 - 0x9c2d4ff7  libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib
0x9c40a000 - 0x9c40afff  com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x9c40b000 - 0x9c419fff  libdispatch.dylib (187.9.0 - compatibility 1.0.0) <2F918480-12C8-3F22-9B1A-9B2D76F6F4F5> /usr/lib/system/libdispatch.dylib
0x9c41d000 - 0x9c52dfe7  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <34E1E3CC-7B6A-3B37-8D07-1258D11E16CB> /usr/lib/libsqlite3.dylib
0x9c5c6000 - 0x9c653ff7  com.apple.CoreText (220.20.0 - ???) <0C3EDD4F-6112-353A-8A3A-8D630182C22A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x9c67c000 - 0x9c7deffb  com.apple.QuartzCore (1.7 - 270.4) <6BC84C60-1003-3008-ABE4-779EF7B4F524> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x9c7df000 - 0x9c875ff7  com.apple.LaunchServices (480.33 - 480.33) <5A4BF529-391E-3987-940E-287ACE56078A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x9cb1c000 - 0x9cb38ffc  libPng.dylib (??? - ???) <75F41C08-E187-354C-8115-79387F57FC2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x9ceae000 - 0x9cee4ff4  com.apple.LDAPFramework (3.2 - 120.2) <39DF72E3-CDAF-33CC-B2DA-67B8891A5CFF> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x9cee5000 - 0x9cf4dff7  libc++.1.dylib (28.1.0 - compatibility 1.0.0) /usr/lib/libc++.1.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 5
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 882
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=189.4M resident=100.9M(53%) swapped_out_or_unallocated=88.5M(47%)
Writable regions: Total=3.3G written=3.2G(97%) resident=3.2G(98%) swapped_out=0K(0%) unallocated=72.4M(2%)
REGION TYPE                      VIRTUAL
ATS (font support)                 31.8M
ATS (font support) (reserved)         4K        reserved VM address space (unallocated)
CG backing stores                  2740K
CG image                             12K
CG raster data                      912K
CG shared images                   3416K
CoreGraphics                          8K
CoreImage                            72K
CoreServices                       2468K
MALLOC                              3.2G
MALLOC guard page                    32K
Memory tag=240                        4K
Memory tag=242                       12K
OpenCL                               28K
SQLite page cache                   192K
Stack                              65.6M
VM_ALLOCATE                        16.2M
__CI_BITMAP                          80K
__DATA                             9828K
__DATA/__OBJC                       120K
__IMAGE                             528K
__IMPORT                              8K
__LINKEDIT                         43.6M
__OBJC                             2936K
__OBJC/__DATA                        12K
__PAGEZERO                            4K
__RC_CAMERAS                        248K
__TEXT                            145.8M
__UNICODE                           544K
mapped file                       111.3M
shared memory                       312K
shared pmap                        6900K
TOTAL                               3.7G
TOTAL, minus reserved VM space      3.7G
Model: iMac11,2, BootROM IM112.0057.B01, 2 processors, Intel Core i3, 3.06 GHz, 12 GB, SMC 1.64f5
Graphics: ATI Radeon HD 4670, ATI Radeon HD 4670, PCIe, 256 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1333 MHz, 0x029E, 0x434D534F344758334D314131333333433920
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1333 MHz, 0x029E, 0x434D534F344758334D314131333333433920
Memory Module: BANK 0/DIMM1, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353637334648302D4348392020
Memory Module: BANK 1/DIMM1, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353637334648302D4348392020
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x8F), Atheros 9280: 4.0.64.8-P2P
Bluetooth: Version 4.0.5f11, 2 service, 18 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: WDC WD5000AAKS-40V6A0, 500,11 GB
Serial ATA Device: OPTIARC DVD RW AD-5680H
USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfa100000 / 2
USB Device: SEMC HSUSB Device, 0x0fce  (Sony Ericsson Mobile Communications AB), 0x0168, 0xfa140000 / 5
USB Device: Internal Memory Card Reader, apple_vendor_id, 0x8403, 0xfa120000 / 4
USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 3
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0xfa111000 / 7
USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfd100000 / 2
USB Device: Flash Reader, 0x3538, 0x0009, 0xfd140000 / 5
USB Device: Built-in iSight, apple_vendor_id, 0x8502, 0xfd110000 / 4
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd120000 / 3
Cometolon
Hi there,
I have none of these problems but it says that there is an update for my phone, and when I click on it I get a message that says:
'Active Java version is incompatible.'
This doesn't work for me either: http://software.sonymobile.com/webupdate/webupdate.jsp?phoneid=xperiau&country=global-en
Greetings.
I have the exact same problem as daddo; the files are on the memory card, but don't show up on the phone. I also added some albums "manually" via drag 'n drop directly into the memory card, and they copied over fine but don't show up in the music player or gallery or wherever they are supposed to be when I disconnect the phone.
The songs that were already on the phone when I bought it, are in the same folder on the memory card, and I can play them just fine when disconnected.
I have a sony xperia arc s,
2.26 Ghz IntelCore 2 Duo
Mac OSX 10.7.4
Sony Bridge 2.2
Android 4.0.4
I hope someone can help, I'm not sure this thread is still active but I hope so Slightly_smiling_Face
I have a slightly different problem with Bridge for Mac. I just bought an Xperia U and when trying to update the software my phone turns off, causing it to say that there is no phone recognised. It does this every time without fail. Please help!
zipo13
Try version 3.0 that just came out.
It fixed my problem and it works great for me with Xperia S
Thanks for your reply. Just downloaded version 3.0 and unfortunately now my phone just isn't recognised at all. I connect my phone and neither the phone or the application do anything. Please get this sorted Sony!
zipo13
A thing that you can do is to remove the bridge for mac from the mac.
delet it from the applications and then delete it from /Library/Application Support/Sony Ericsson Bridge For Mac
Also remove the com.sonyericsson.Sony-Ericsson-Bridge-for-Mac.plist file from the  /Library/Prefrences.
The reinstall.
On the other hand it looks to me as you phone is acting up and not the bridge for mac so  I wouldn't get my hopes up...
Did you try PC Companion?
Does it act the same?
