Problem with Music widget on lockscreen bug
fmcc789
Although it was originally working, the lockscreen widgets for the walkman app and spotify app no longer appear when music is playing. The clock widget is instead always shown, although there is a slight flicker when you first turn on the screen as if it is trying to switch to the music widget, and clearly there is a bug in the software.
Has anyone else experienced this?
44 REPLIES 44
Rickard
First try restarting the phone if you haven't done that and see if it helps.
If a reboot doesn't help, go to Settings -> Apps -> All -> Lock screen -> Clear data and try again.
2cooll
I have the same problem, tried clearing the lockscreen app data and the problem persists even after a reboot.
2cooll
Anyone find a solution to this? I have uninstalled the Walkman app in the app list, then reinstalled the latest version of the app through the automatic updates. Still not able to control the walkman app or even see it on the lockscreen, even when music is actually playing.
Archanos
Did you try to play with lock screen widgets (generally)? There are number of them, if everything failed you could try to manually add/remove widgets to the locks screen (you can do this by swiping the clock widget to the right, then [+] mark will appear so you can add more, or just tap&hold any of the widgets pretty much the same way like on the home screen to move them around or delete). Uninstall spotify first if you didn't already. Then play something on the walkman and go to the lockscreen where should be the Walkman widget and then try what I said.
You actually are the first one who have this problem so I guess it's not some common bug. If nothing else help, you can always do a SUS clean repair.. but I have no more ideas for now that could make you avoid it. Sorry Slightly_frowning_Face
Dracon
I don't know if my issue came with 534 update because I didn't test it prior to.
It is very similar to fmcc789 though there is more.
First, you can add "lock widgets" to the lock screen which you can swipe between them right or left, where camera is a fixed right-end widget. All this is very useful (I adore the calendar widget on lock screen) and works fine but as soon as I use the Walkman app or a 3rd party music app (XiiaLive) the lock screen flickers and I can't swipe to other widgets (stuck to the central). it actually swipe but comes back so fast to the central widget that the others are unusable.
Hopefully the next firmware update will fix everything 😄
Dracon
For now I would like to know if it is a confirmed bug and if they actually are working on it.
2cooll
Firstly, I had this problem before I upgraded to 534. The lockscreen controls for the Walkman app and Spotify both stopped working.
Things I've done and it is still not fixed:
Removed dashclock and all its extensions
Uninsulated and reinstalled the Walkman app
Updated the Walkman app
Updated the firmware to 534
My current workaround:
Use another free music player whose lockscreen controls work fine, n7 player.
Sony should fix the bugs if they want people to continue to use their Walkman app and their music unlimited service after the 60 days free.
aMUSEd1
I have the same issue.
Initially it worked with SW Version .518
Please fix it soon because this is annoying.
Regards
kolkis
Do this way can fix lock screen sound? Cause i barley hear it!!
