Hello to everybody!
I've a SE ELM and I've a problem with google maps 3.0.0 (pre-installed application under "location services"). Google maps always says: "Data connection lost,retrying...". Please note that data connection works with other apps (web browsing, wisepilot, youtube etc.), as I have properly configured the Internet Properties under menu "Application". Unfortunately, Google Maps is an embeddet application so I don't understand how to set properties for internet connection...
Have you any suggestion?
I've tried to download google maps from google web site but it seems that only version 2.3.2 is available, and GPS doesn't work with such a version...
Thanks!
meriadoc
http://www.sonyericsson.com/cws/support/mobilephones/downloads/elm?cc=gb&lc=en If you open Google Maps--Options--Help--Reset Google Maps.Otherwise, try running the update service and/or a phone repair with PC companion, remembering to back up your phone data on PC/PC companion/memory card first.You can also try a master reset, if none of the above fix the problem.Hope this helps.
